MONACOR SPP-110/4 Hi-Fi Hi-Fi 60W Bass Speakers 4Ω
Monacor SPP-110/4
Reference : 7025
29,20 €tax incl.
24,33 € tax excl.
60 W Hi-Fi Woofer MAX, 4Ω (/ 4)
with PVC / Carbon membrane. Decompression and cooling by the core. For 2-way library or Appolito systems.
SPP-110/4 = 4 Ω
Impedance (Z) 4 Ω
Resonance frequency (fs) 53 Hz
Maximum bandwidth f3-8000 Hz
Maximum power 60 WMAX
Nominal power (P) 30 WRMS
Average sound pressure (1 W / 1 m) 90 dB
Compliance susp. (Cms) 1.95 mm / N
Movable mass (Mms) 4.3g
Mechanical overvoltage. (Qms) 2.01
Electrical overvoltage (Qes) 0.46
Fact. total overvoltage (Qts) 0.37
Volume equ. (VAS) 8 l
ReDC resistance. (Re)3.3 Ω
Force factor (BxL) 3.3 Tm
Inductance coil (Le) 0.3 mH
Coil diameter 25.5 mm
Coil support Alu
Linear Excursion (X MAX)± 2 mm
Transmitting surface (Sd) 55 cm2
Magnet weight 10 oz.
Weight 0.9 kg
PDF-Download
Speaker TypeMidrange
Colissimo - TNT - SoColissimo
