SUPRAVOX 165-2000 Speaker Driver Full Range 35W 4 Ohm 94dB 60Hz - 20kHz Ø 16cm
Supravox 165-2000 - 16 cm - 94 dB - 60 Hz / 20 kHz
By buying this product you get 70 loyalty points
Reference : 38
709,00 €tax incl.
590,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
The 165-2000 was designed according to the same philosophy as for the 215-2000. Its engine consists of a block of alnico of 1.2 kg to obtain a magnetic field of 20000 Gauss. His qualities are predominant in the medium and extreme high.
Used as a flat panel, with a rear roof or in acoustic line, it is one of those rare broadband that has a bandwidth that reaches 20 kHz without needing a bicone.
Sensitivity 1 W / 1m to Fs94 dBfs75 Hz
Bandwidthyle = "font-family: Verdana, Arial, Helvetica, sans-serif; font-size: small;"> 60 to 20 kHzRe4.1 ohms
Impedance4 ohmsqt0.74
Power consumption RMS35 WQe0.8
Weight3.2 kgQm9
Suspension5-ply paperVas32 L
Linear Excursion10 mmbl3.9
Alnico Magnet1.2 kgcms0.73
Magnetic field2 Tmms
5.5 g
HP Diameter 185 mmsd
165 cm²
Speaker Power (W RMS)35.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)160.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)60
Highest frequency (Hz)20000
