FIIO KA3 Portable DAC Headphone Amplifier ES9038Q2M Balanced 32bit 786kHz DSD512
FiiO offers with the KA3 a compact and particularly powerful portable DAC and headphone amplifier combo. Featuring a USB-C input, it is an ideal companion for use with a current smartphone. It also features a dual output, with single-ended 3.5mm jack and balanced 4.4mm jack to match your listening device.
Reference : 15763
89,90 €tax incl.
74,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
FiiO KA3
FiiO KA3 DAC Amplificateur Casque Portable ES9038Q2M Symétrique 32bit 786kHz DSD512
Optimized architecture
The KA3's circuitry uses quality components in an intelligent architecture to achieve excellent performance and clear, detailed sound reproduction.
High performances DAC
The digital / analog conversion stage uses an ESS ES9038Q2M DAC chip. This one ensures a sound restitution recognized for its great precision and transparency. Moreover, it allows the support of high resolution audio streams, up to PCM 32bit 768kHz and DSD512.
RGB indicator
The KA3 features a convenient circular RGB LED indicator. It changes color to indicate the sample rate of the file being played.
  • Blue : 48kHz and below
  • Yellow : 48kHz and above
  • Green : DSD
Control app
FiiO provides a control application for Android, allowing to access many parameters to adapt the sound of the KA3 to your desires. It is for example possible to access 7 filters, to modify the gain level or to adjust the channel balance.
The FiiO control application is only available for Android devices.
Product typeDAC and headphone amplifier
DAC ChipES9038Q2M
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Output powerSingle-ended: 130mW @ 32Ω
Balanced: 240mW @ 32Ω
Noise floorSingle-ended: 3.9µV / 4.2µV
Balanced: 4.4µV / 4.3µV
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Dimensions56.3 x 20.2 x 12mm
Weight17.5g
Package1x FiiO KA3
1x USB-C to USB-C cable
1x USB-C to USB-A cable
OutputJack 4.4mm
OutputJack 3.5mm
5 reviews
Indispensable pour écoute nomade sur Smartphone
Ayant deux casques de qualité, je voulais pouvoir les utiliser sans souci sur n'importe quel smartphone. Après un moment de recherche, je me suis arrêté sur le Fiio KA3. Et franchement je ne le regrette pas le moins du monde.
Je peux maintenant profiter en mode "nomade" de mes casques ( Hifiman Sundara & Denon AH-D5200 ) sans le moindre souci de performances ( tant puissance que qualité ). ce DAC rikiki permet de les "driver" sans aucun problème. De plus ayant changer de smartphone, le Samsung A53 ne dispose plus de port 3.5mm jack. je me balade donc en permanence avec mon DAC. Ecoute de fichiers lossless ( FLAC ) et streaming via abonnement Qobuz et vrai régal.
J'ai fait écouter le combo à plusieurs collègues et franchement ils étaient stupéfaits de la qualité de rendu.
Je ne peux que recommander ce produit. ( livraison rapide et soignée comme toujours avec audiophonics)
PS : non, je ne suis pas sponsorisé ^^ mais quand un produit est bien il faut le dire. Quand il est mauvais aussi ^^
This review has been posted for FIIO KA3 Portable DAC Headphone Amplifier ES9038Q2M Balanced 32bit 786kHz DSD512
Très bon DAC
Très bon dac et ampli casque. J'avais un radson earstudio dont j'étais déjà très content, mais avec ce Fiio K3, j'ai une meilleure résolution: le son est clair et limpide.
Seul bémol, j'imaginais la puissance de sortie plus importante sur le mini-jack 3,5 mm.
Bilan globale : je recommande !
Top quality :-)
Avis posté avec encore peu d'usage, mais le gain pour mon usage est important.
- 1 usage classique : écoute audio de musique sur casque : meilleure spacialisation, la scène sonore s'est ouverte, et chaque instrument est plus "individualisé" et moins écrasé par les autres présents à l'enregistrement. Quand une corde est grattée ou pincée à coté d'une voix, elle se sépare mieux et vient enrichir l'écoute.
Belle qualité sonore, assez étonnante pour le prix car pour avoir une belle scène sonore, j'utilisais un ampli casque à tube seulement jusqu'ici, mais pas transportable.
- 1 usage particulier : écoute de fichiers audios pour faire de la retranscription pro. Les fichiers sources ne sont pas forcément top qualité, plusieurs interlocuteurs pouvant parler en même temps voire avec un fort bruit de fond : la séparation de chaque source est meilleure et chaque voix est donc plus facilement audible et compréhensible.
Moindre fatigue du coup :-)
Ceci est mon premier DAC, donc je n'ai pas de point de comparaison avec d'autres, mais j'en suis très satisfait.
Qualité audio franchement très supérieure à la carte audio intégrée à mon PC portable (PC entrée de gamme valant seulement +/- 800 €) dont la carte son commençait à dysfonctionner.
DAC portable = contournement du problème ;-)
Très bien sur pc portable
Venant d'acquérir un pc portable,j'utilise foobar règle sur Wasapi:c'est juste parfait...vraiment étonnant ce petit dac
Trés bien pour un smartphone
Je rechercherchais un petit dac pour connecter à mon smartphone Samsung,afin de lire ma musique stockée sur une micro sd(que du lossless ou supérieur),suite à un essais peut concluant avec un FX Audio dac X6.
C'est très très bon, même en utilisation sur un système classique ampli rega et enceintes monitor audio.
L'appli permet de sélectionner plusieurs filtres passe-bas (c'est subtil mais il me semble que ça modifie l'impression d'effet 3D )
En tout cas,quand je pense à mes début en hifi il y a plus de 20 ans avec des dacs séparé et mes centaines de CD et ce que maintenant on peut faire avec ce minuscule appareil à 100 euros et de la musique stockée sur une minuscule carte mémoire,c'est vraiment bluffant.
FiiO offers with the KA3 a compact and particularly powerful portable DAC and headphone amplifier combo. Featuring a USB-C input, it is an ideal...
