SMSL iDEA USB DAC Headphone Amplifier XMOS U208 ES9018Q2C DSD512 Black
Reference : 11912
89,00 €tax incl.
74,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
    Discover the all-new USB DAC / Portable Headphone Amplifier from SMSL, the iDEA. It will be the perfect companion for OTG or iOS compatible mobile listening. Whether on tablets, Android smartphones, iOS smartphones or iPad, the iDEA SMSL guarantees High Fidelity and High Definition up to 32Bit / 384kHz, with DSD support thanks to its ES9018Q2C conversion chip.
    Hi-Res Audio SMSL iDEA
    The headphone amplifier is directly integrated into this conversion chip ES9018Q2C, which is a DAC designed by ESS SABRE especially for mobile and portable applications. It accepts headphones with an impedance between 30 and 300 Ohm.
    The USB XMOS XCore U208 input of this iDEA SMSL is a real strength for transmission quality, accepting sampling rates up to 32Bit / 768kHz as well as DSD up to DSD512.
    This iDEA SMSL is Plug & Play, it does not require any driver to work except when used in USB DAC mode with Windows. In this case, you will need to download the corresponding XMOS driver available in the "Download" tab of this page.
    CAUTION: Be sure to check the OTG compatibility of your terminal!
    The use of USB OTG DACs requires a compatible application such as Hiby Musique: Download Hiby Musique
    Test by Audio Science Review
    Audio science review SMSL IDEA DAC
    SMSL IDEA was subjected to a complete test bench by the plaform Audio Science Review you can find the results on this link.
    Technical Specifications:
    • DAC ESS SABRE : ES9018Q2C
    • USB XMOS : XCore200 XU208
    • THD+N : 0.0011%
    • Signal-to-noise ratio : 108dB
    • Dynamic range: 121dB
    • Impedance range: 16 - 300 Ohm
    • Headphone amplifier: 35.8mW (32Ohm) / 31.6mW (64 Ohm)
    • Supported sampling rates: Up to 32Bit / 384kHz
    • DSD support: DSD64 / DSD128 / DSD256 / DSD512
    • Integrated ultra-low noise LDO power supply
    • Hi-Res Audio certified, by the Japan Audio Society
    Compatibilities:
    • Active speakers / Amplifiers
    • Windows (With Driver)
    • Mac OS and iOS (Native)
    • Android 4.0 and newer
    Weight, package, accessories:
    • USB Microphone Input
    • Analog output 3.5mm jack
    • Weight only: 9.5g
    • Dimensions: 60x16x6mm
    • Color: black
    • Supplied with cables: Micro USB - USB-A / Micro USB - Micro USB / Micro USB - Micro USB - USB-C
    Caractéristiques SMSL iDEA ES9018
    OutputJack 3.5mm
    Download
    Driver SMSL iDEA
    Windows Driver (old version)
    Download (0)
    Driver SMSL 2018 V4.47
    Windows Driver (newest version)
    Download (2.79M)
    Très convaincant !
    Un retour sur ce petit DAC : après une première déception rapidement surmontée car liée à un mauvais paramétrage de l'OTG sur mon smartphone, ça fonctionne, même avec Deezer ou Youtube. Il semble donc que les dernières versions d'android gèrent la transmission du son via USB sans nécessiter d'application tierce spécifique, bonne nouvelle !
    Il y a un autre problème, que j'avais déjà vu sur des forums : il arrive que le son ne passe pas au démarrage d'une écoute, ça se règle en deux secondes par un débranchage-rebranchage du câble USB.
    Voici ma configuration la plus fréquente d'utilisation : smartphone Oneplus 3T sous android 8.0.0 (et fonctionnalité stockage OTG activée !), casque Sennheiser Momentum 2.0 (impédance 16 Ohms). J'ai aussi testé sur ma tablette sous android 5.0, ça marche aussi sans problème avec les services de streaming évoqués. Sur mon PC sous debian 9 pas de souci non plus, je n'ai pas eu besoin d'installer de driver spécifique, il suffit simplement de diriger le son vers le DAC dans les paramètres audio.
    Qualitativement : pas de bruit ni de souffle à signaler malgré la faible impédance du casque. Les premières écoutes confirment ce que j'ai pu lire sur la qualité de la sortie jack du Oneplus 3T : elle est déjà bonne mais là avec le petit Idea, waouh !!! Je n'ai pas les termes et connaissances techniques suffisantes pour livrer toutes mes impressions, mais on gagne en clarté sur toutes les fréquences, j'entends une différence notable sur les voix, les médiums et les aigus, mais les basses vibrent bien aussi, chaque gamme de fréquence est plus détachée, l'écoute est donc moins confuse, plus claire.
    Prochaine étape, passer aux fichiers Hi-Res !
    This review has been posted for SMSL iDEA USB DAC Headphone Amplifier XMOS U208 ES9018Q2C DSD512 Black
