SMSL iDol+ USB OTG DAC Headphone Amplifier Android iOS MAX97220A Black
20%
3.8 / 5
Reduced price!
Reference : 11346
Limited special offer
39,90 €tax incl.
-20%
31,92 €tax incl.
26,60 € tax excl.
Available
Shipping date: 19-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Here is the iDol +, the new portable USB DAC from SMSL, following the success of their iDol . It will be your ideal companion for a listening nomad compatible OTG or iOS . Whether on tablets, Android smartphones, iOS smartphones or iPads, the SMSL iDol + High Fidelity Guarantee and High Definition up to 24Bit / 96Khz or 16Bit / 192kHz .
The headphone amplifier chip is the MAX97220A and the USB VT1620A chips. The latter uses an ultra low power (0.1W) technology, which allows it to be powered and used by any mobile device.
This iDol + SMSL is Plug & Play , it does not require any driver, just plug it in to use it. It also acts as an excellent USB interface allowing the use of your mobile source on a High Fidelity DAC (smartphones, tablets, portable laptops).
WARNING ! Be sure to check the OTG compatibility of your terminal!
The use of USB DACsOTG requires a compatible application such as Hiby Music: <a style = "font-size: 14px;" href = "https://play.google.com/store/apps/details?id=com.hiby.music&hl=en" target = "_ blank">Download Hiby Musique
Test, essai par QOBUZ du SMSL IDOL +
Technical Features:
  • THD + N: 0.025%
  • Power of 64mW at 64Ohm (@ 1% THD + N)
  • Noise Ratio: 85dB
  • Dynamic range: 97dB
  • Sampling rate: 24bit / 96kHz or 16bit / 192kHzInput Micro USB </ Li>
  • Analog Output 3.5mm
Compatibilities:
  • Windows
  • Mac OS and iOS
  • Android 4.0 and newer </ Li>
Weight and package, accessories:
  • Weight: 11g
  • Dimensions: 55x21x8mm
  • Black color
  • Comes with a Micro USB to USB-A cable Comes with micro USB to micro USB OTG cable Delivered with small black carrying pouch </ Li>
ComponentMAX97220A
MaterialAluminium
ColorNoir
StructureAluminium
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
4 reviews
Version d'android.
Ne fonctionne pas sur Smartphone Archos 50H android 4.3. La diode reste tristement éteinte. Dommage de ne pas pouvoir balader ma musique !
Fonctionne parfaitement sur tablette Archos 101 android 5.
Immédiatement reconnu comme carte son sur PC Debian GNU/Linux.
Qobuz s'invite volontiers sur ce mini DAC + Casque Superlux HD668B.
Tutti bene pour le prix de l'ensemble à condition de changer de smartphone.
À la maison, je préfère la parfaite union d'un FX-Audio D802C + Wharfedale-E50.
This review has been posted for SMSL iDol+ USB OTG DAC Headphone Amplifier Android iOS MAX97220A Black
Fonctionne en OTG Mais...
DAC acheté pour aller de concert avec un téléphone portable sans prise jack. Fonctionne très bien (MP3, FLAC, DSD) mais nécessite pour bien fonctionner une app payante (USB Audio Player PRO) . Parcontre KO avec Spotify (90% de mon usage) contrairement a ce qui est indiqué sur le site. Plutôt déçu de mon achat donc.
Vous pouvez utiliser Hiby Music parfaitement gratuit.
Aucune mention n'est faite à la compatibilité Spotify, Deezer, etc... (bien connus pour verrouiller leurs application !)
Fait le job.
J'ai pris ce petit dac, sur la foi des bonnes critiques de son grand frère. Petit, léger, peu cher incontestablement il améliore grandement le rendu des format lossless. en écoute à partir d'un smartphone, sur enceinte type bluetooth, mais avec un câble, ou sur un casque. Passe difficilement sur ma châine hifi moyen de gamme, bonne dynamique, ton neutre, mais son quand même brouillon. Au final bon rapport qualité prix, pour une utilisation nomade.
Très bien
Bonjour,
J’ai acheté et testé le SMSL Idol+
Configuration des essais :
- Source : iphone (Qobuz desktop) ou PC (carte connexant smart audio HD +foobar2000 + fichiers HiRes),
- Casques : nomade Sennheiser PX 360 – salon Sennheiser HD 650.
Résultats :
Partie ampli :
- Avec l’iphone, l’ampli DAC apporte la dynamique qui manque à l’appareil. Dans mes environnements d’écoutes, principalement le train, l’iphone seul a du mal à piloter le casque nomade. Avec l’Idol, c’est parfait. L’ampli DAC peut même driver le casque de salon.
- - Avec le PC, la dynamique de l’ampli apport peu. La carte audio étant suffisante.
Partie DAC et écoute :
- Quelques soient le casque et la source, la scène sonore est plus large, plus aérée. Les aigus ne sont pas agressifs, les graves sont tendus.
- L’apport du SMSL Idol est même sublimé avec le casque HD650. On est dans un autre monde. Les qualités du casque sont propres à sa configuration ouverte. Dommage que cela ne soit pas adapté à une utilisation nomade.
Le défaut :
- Le SMSL est assez sensible aux perturbations causées par les ondes téléphones. Vous savez, le tut tulutut quand votre téléphone est proche des hauts parleurs de votre PC. C’est ballot pour un ampli DAC mobile… Il faut éloigner l’idol de l’iphone. Préférez l’adaptateur camera USB d’iphone plutôt que des adaptateurs plus courts. (avec Iphone, il faut l’adaptateur pour faire fonctionner le DAC). Sinon, reste le mode avion.
Conclusion :
L’ampli DAC SMSL Idol+ apporte un vrai plus en qualité et en dynamique pour l’écoute nomade par rapport aux solutions intégrées dans les appareils.
Si vous utilisez aussi votre lecteur mobile comme source (avec la prise écouteurs) sur un ampli de salon, vous pourrez même placer l’idol entre les deux.
A 40€, le rapport qualité prix est sans appel.
