TOPPING NX7 Portable Headphone NFCA Amplifier Balanced Silver
The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA amplifier circuit specifically designed for portable amplification systems. Its low power consumption allows for long battery life, while ensuring excellent audio performance, with a THD+N 0.00007% and an SNR of 135dB. This module is powerful enough to accompany both demanding headphones and extremely sensitive earphones.
Reference : 15864
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Topping NX7
Topping NX7 Amplificateur Casque Portable NFCA Symétrique Argent
Topping NX7 Amplificateur Casque Portable NFCA Symétrique Argent<span id=" width="1082" height="804" />
High power in a compact size
The NX7 is capable of delivering a power of 2x180mW under an impedance of 300Ω, with what's more an adjustable gain on three levels: -13.8dB, -0.1dB or 13.9dB. Thus, it will have no trouble powering high-impedance headphones. Moreover, even with a high power of 200mW, the distortion remains extremely low with a measurement at 0.00008%. The background noise of the NX7 is less than 0.3µV and therefore perfectly inaudible. Finally, its impedance of only 0.1Ω ensures a sound reproduction without coloration, even with high sensitivity headphones.
Robust design & Dual output.
The NX7's components are clad in a sturdy aluminum chassis with flanges to protect the connectors and plugs, while preventing unwanted volume changes.
On the output side, the NX7 provides both a balanced 4.4mm jack output and a single-ended 3.5mm jack output, adaptable to any listening equipment.
An important battery life
Totally optimized, the NX7 offers a consequent autonomy being able to reach 20 hours in the case of a use with a low or average gain. In high gain mode, the autonomy remains important with its 10h in reading. It integrates for that a battery of not less than 4000mAh.
Product typePortable headphone amplifier
Amplification moduleNFCA
Input1x Jack 3.5mm
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Measurements
Single-ended Jack 3.5mm outputBalanced Jack 4.4mm output
THD+N @ 1kHz (A-Weighting)< 0.00008% @ Output = 200mW, 32Ω
< 0.00007% @ Output = 83mW, 300Ω
THD @ 20Hz-20kHz (90kBW)< 0.001% @ Output = 200mW, 32Ω
< 0.0002% @ Output = 83mW, 300Ω
SNR @ Max out, 1kHz (A-Weighting)135dB135dB
SNR @ 50mV Output level, 1kHz104dB104dB
Dynamic range @ 1kHz (A-Weighting)135dB135dB
Frequency response20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)
Output level7.4Vpp @ G=L
11Vpp @ G=M
21Vpp @ G=H
7.4Vpp @ G=L
11Vpp @ G=M
21Vpp @ G=H
Measured noise level (Audio Precision) @ A-Weighting< 0.7µVrms @ G=L
< 0.7µVrms @ G=M
< 2.0µVrms @ G=H
< 0.7µVrms @ G=L
< 0.7µVrms @ G=M
< 2.0µVrms @ G=H
Actual noise level* @ A-Weighting< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 1.3µVrms @ G=H
< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 1.3µVrms @ G=H
Channel crosstalk @ 1kHz-91dB-96dB
Input sensitivity13Vrms @ G=L
4Vrms @ G=M
1.5Vrms @ G=H
13Vrms @ G=L
4Vrms @ G=M
1.5Vrms @ G=H
Gain-13.8dB @ G=L
-0.1dB @ G=M
13.9dB @ G=H
-13.8dB @ G=L
-0.1dB @ G=M
13.9dB @ G=H
Output impedance< 0.1Ω< 0.1Ω
Output power2x1200mW @ 16Ω, THD+N <0.1%
2x1400mW @ 32Ω, THD+N <0.1%
2x820mW @ 64Ω, THD+N <0.1%
2x180mW @ 300Ω, THD+N <0.1%
2x90mW @ 600Ω, THD+N <0.1%
Adapter impedance> 8Ω
* The actual noise level is obtained by boosting the noise of the NX7 by 40dB using a low noise amplifier before the APx555B, then dividing the measured value by 100.
Dimensions135 x 70 x 16mm
Package1x Toping NX7
1x Jack 3.5mm cable
1x USB-A to USB-C cable
2x Rubber bands
1x Rubber pad
Topping NX7 Amplificateur Casque Portable NFCA Symétrique Argent Topping NX7 Amplificateur Casque Portable NFCA Symétrique Argent
InputJack 3.5mm
OutputJack 4.4mm
OutputJack 3.5mm
ColorSilver
The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA...
