Ramiro F.
Ramiro F.
Marcus L.
Fabrice T.
R.A.S
Conforme à la description.
Fabrice T.
Super pratique
Utilisé pour déclencher deux ampli de puissance quand j'allume mon ampli Home Cinéma, c'est simplement parfait.
Fabrice T.
Utilisation parfaite pour doubler la sortie trigger d'un ampli HC vers deux amplificateurs de puissance avec prise IEC déclencheur .
Mohamed Nabil M.
Yarbo SP 1100 PW - Amazing cable
I run 2 accuphase amplifiers on B&W 8th series speakers. and i bought expensive sets of cables to use for my system. out of curiosity I ordered 2 meters of this cable combined with Neotech terminals to test how good they stack compared to my AQ Hurricanes, and once I get the cable in my system i felt the difference. so much musicality and reveal. tonal balance and layering is excellent, sound stage as wide as it could be.... this cable beats the best cable i had in my system. i retuned the cables that i had still unopened and i purchased enough Yarbo to replace all the power cables in my system... cannot wait to see the final results.. highly recommended for high end gear
Paulo L.
ASTELL&KERN A&NORMA SR25 Digital Audio Player DAP HiFi 2x CS43198 Bluetooth WiFi 32bit 384kHz DSD256 MQA The SR25 is the second model in Astell&Kern's A&norma range, a high-end DAP that fully embraces the brand's philosophy and technology, now available to the general public. The...
A mixed experience
5 stars for Audiophonics.
3 stars for SR25.
Very well built, small form factor and aesteticaly pleasant. In the sound quality department: honestly, no better than my DC04, also bought here, docked to my Galaxy S10+ 12GB/1TB version! And the processing power it's not enough to handle Tidal offline properly!
Pascal g.
bon produit à petits prix
pour ma part je peux vous dire que ce produits est conforme à mes attentes, et surtout que le vendeur est très sérieux serviable et très réactif!
Arnaud F.
Très très bon dac Français !
Je suis très ravi de mon dac.
Le fait de monter soi même son dac est ludique et très facile à mettre en œuvre.
Toutes les pièces sont de très bonnes qualités et tout se montent facilement.
J'ai associé à l'evo-sabre, son alimentation audiophonics dédiée pour mieux l'alimenter.
Le dac est branché sur un préampli Atoll Pr200se, un ampli am200 signature Atoll avec des câbles rca Canare.
Mes sources sonores viennent de Qobuz.
L'écoute est très belle, la scène sonore est ample sans agressivité avec des graves présents mais non envahissants, des médiums et aigus bien définis sans être criards.
Je le pilote grâce à bubbleupnp (très bonne application avec un développeur très réactif) depuis mes appareils Android.
Pour le faire fonctionner, mon choix s'est arrêté sur Volumio qui me donne sur mon installation, le meilleur résultat: scène large, écoute de chaque instrument détaillé, grave présent et bien défini, médium et aigu sont agressivité et donc pas de fatigue à l'écoute.
L'écoute est également détaillés avec beaucoup d'informations et de précisons.
De plus, avec volumio s'est très facile à installer et l'utilisation est quasi immédiate après l'installation.
J'ai fait d'autres essais pour piloter le EVO-SABRE.
Avec MoOde: je n'ai pas du tout aimé, la scène était trop centrée ce qui faisait que je perdais la largeur de la scène, tout semblait confus, beaucoup moins défini, un gros bof !
PiCorePlayer: moins facile à installer que Volumio ou MoOde mais avec les tutos que l'on trouve sur leur site, cela se fait facilement quand même.
L'écoute est agréable, les graves sont encore plus précis que Volumio mais la scène est beaucoup moins large et n'utilise pas tout l'espace possible entre les enceintes.
L'écoute est également moins détaillés moins analytique.
Par contre point de vue utilisation depuis un appareil, c'est beaucoup moins pratique qu'avec Volumio ou MoOde grâce à bubbleupnp.
Si je n'ecoutais que du rock, funck, jazz, je crois que mon choix pourrait resté sur PiCorePlayer mais comme j'écoute énormément de musique musique classique en plus de celle citées avant, ma préférence va pour Volumio pour sa largeur de scène sonore et à la présence de beaucoup plus de détails.
Par contre, j'ai un petit reproche à l'utilisation du EVO-SABRE avec bubbleupnp, c'est la durée de la mise en place d'une playlist à cause de la version du openhome dans l'image Volumio proposée par audiophonics.
Mais grâce à la très grande écoute de ses clients et à la très grande réactivité de leurs services, ce petit reproche devrait être corrigé dans une future mise à jour de la version Volumio.
Une dernière remarque, c'est l'immense qualité de service chez Audiophonics, je n'ai jamais rencontré une entreprise sur le net qui soit autant à l'écoute de ses clients et qui cherche à aider, résoudre les problèmes avec autant de gentillesse, d'écoute et de professionnalisme.
Vive le fabriqué en France et bravo à Audiophonics !
Très pratique
Les liaisons fibre optique sont très pratiques : pas de parasites, pas de perte de qualité, pas de soudures, et fil très fin.
Le plus gros, c'est le connecteur, mais avec cette solution de connecteur à clipser, on peut faire des câbles à la longueur voulue, et on peut les tirer dans une gaines même déjà par mal encombrée (acheter un câble optique audio, couper l'une des extrémités, puis refaire la connexion une fois la fibre passée en gaine).
Vytautas Š.
VYTAUTAS
prodotto di qualità
Joseph W.
Conforme à mes attentes.
Vytautas Š.
VYTAUTAS
prodotto di qualità
Vytautas Š.
Joël C.
MUNDORF MLYTIC AG Capacitor 63V 8200μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Condensateur 63V 8200µF
Très bon produit de qualité ! Servis rapide ! Le prix un peu élevé...
Arnaud F.
Très bonne prise
Très bonne prise secteur.
Très facile à mettre en œuvre.
Je ne sais pas si cela apporte une meilleure qualité audio mais de sûr les contacts sont très bons.
Arnaud F.
Très bon câble secteur
J'ai acheté ce câble sur recommandation de audiophonics pour alimenter mon dac EVO-SABRE.
Le câble est facile à mettre en œuvre.
Comme c'est mon 1er vrai câble secteur, je ne sais pas si il est meilleur qu'un autre mais en tout cas il a apporté une certaines sérénité dans les écoutes comme avec mon alimentation séparée audiophonics.
L'écoute de la scène sonore est plus ample, mieux définie.
Arnaud F.
Très bonne prise
Très bonne prise, facile à mettre en œuvre.
Après je ne sais pas si elle apporte une meilleure écoute mais les contacts sont de très bonnes qualités.
Arnaud F.
J'ai acheté ce câble sur recommandation de audiophonics pour alimenter mon ampli et préampli ainsi que mes barrettes secteurs (j'en ai même profité pour refaire le câblage intérieur en étoile en enlevant les barrettes d'origine).
Le câble est facile à mettre en œuvre et malgré sa section est assez souple.
Andrea G.
Eccellente
Prodotto ottimo, tempi di consegna perfetti.
Jérôme S.
POWER DYNAMICS PDX015 Phono USB Preamplifier - Audacity The PDX015 preamp by Power Dynamics allows you to connect a vinyl player to a computer or a laptop. A recording software is provided to convert your disk collection to...
Copie amélioré
Appareil compact et simple d'utilisation avec le logiciel Audacity.
Possibilité de copier tout type d'appareils y compris des CDs pratique quand on ne possède plus d'ordinateur de bureau...
Qualité du son amélioré par le système riaa permettant de redécouvrir ses vieux vinyles !
Jean Jacques S.
NICHICON KG GOLD TUNE HiFi Audio Capacitor 50V 10000µF The Nichicon capacitors of the KG range have been specially designed for audio. Thus, they allow to achieve a high fidelity sound reproduction and can be integrated in different...
Qualité
Condensateur audio qui remplit bien son rôle et de abrication sérieuse.
Gustav W.
Best dac for me!
Great smooth sound! Big and detailed. Can only recommend! Solid build and really everything one could need. Maybe there are better dacs out there, marginally better maybe but not price/performance ist simply stunning
Gustav W.
Great cable for mobile devices
Great cable! Solid build. Can only recommend. As usual, Audiophonics is a really good shop!
Gustav W.
FIIO BTR5 2021 Balanced Headphone Amplifier DAC Bluetooth 5.0 Receiver 2x ES9219P CSR8675 XMOS 32bit 384kHz DSD256 MQA The FiiO BTR5 2021 is a compact, portable headphone amplifier, offering excellent design quality and versatility for enhanced listening at home or on the go.
Great dac!
Great produkt! Great sound, well made. Using it in my car and improves sound vastly. Highly recommended! Reconnects right away when I unlock the car
Benoit N.
ELECAUDIO BP-207 Binding Posts Carbon / Gold Plated 24K Ø5.5mm The BP-207 from Elecaudio is a resolutely HiFi speaker terminal (sold in pairs), whose contacts are fully 24k gold plated. It accepts large diameter cables (up to Ø5.5mm)...
Très belle qualité de fabrication, grande robustesse. Ils sont assez imposants, j'aime bien leur look.
Niveau qualité sonore: RAS, je ne m'avancerai pas à dire qu'il y a une quelconque différence sonore avec d'autres car je n'ai pas testé et de toute façon il faudrait avoir un système d'une qualité incroyable pour entendre une différence.
Vivement conseillés, car ils font propres, pro et pas cheap.
silence dynamique naturel des voix etc.
très beau câbles finitions superbe. du pro a prix contenu. utilisé entre prise secteur et conditionneur secteur keces bd1200. toutes les qualités trouvées sur le petit frère a 50euro. en mieux partout avec un aigus superbe qui file haut sans dureté et une belle fluidité.. les graves ont prix en profondeurs dynamique et définition incroyable. le medium et aussi fluide et musical et l espace stéréo et plus précis large et profond.. excellent câbles donc a recommander les yeux fermés.il y a se pendent un probleme .le câble que j ai reçu na aucune indication de la marque du model et surtout du sens de fonctionnement.. j ai du le faire a l oreilles et démonter remonter les prises a deux reprise pour trouver la bonne direction ;-).. svp audiophonics. vérifier avant l envois que sais le bon câble avec au moins les indications sur le tronçon du bon sens pour un montage facile ..merci pour le service impeccable quand les articles sont en stock ;-)
ps; y a t il une astuce pour trouver le bon sens de fonctionnement sans avoir a démonter remonter pour l entendre.. si qq un a une idée ;-)
Alfredo B.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 3.9µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Muy buena relación calidad / precio.
Recibido muy rápido, excelente comportamiento y mejora de prestaciones en crossover.
Alfredo B.
François D.
LJM stereo Loudspeakers protection 15A Protection module for speaker
Protection HP
Je vous ai contacté il y a quelques semaines, pour le raccordement du module de protection. J'ai fait des recherches, et les infos que vous m'avez transmis sont fausse, vous m'avez dis d'utiliser un transfo de 12 volts, et c'est faux quand fait des recherches chez le fabricant du module. C'est quand même fou qu'un site comme le votre qui vend des produits techniques donnent de fausse info a c'es clients. Vraiment pas sérieux
Jean-Paul L.
Tres bon RQP
Néammoins il n'a pas le coté chantant et la dynamique des trés bons amplis anglais (à 790€ par exemple et pour ne dire le nom)
Il lui manque une âme, du corps, de la moelle.
Il est paradoxal, car il donne beaucoup de détail mais le medium est comme limité, retenu, manquant de chaleur !!!!
Mais bon à ce prix il est pas mauvais du tout loin de la.
Vertical Support for Capacitor Ø65mm This PVC support will allow you to hold a 65mm diameter capacitor in a vertical position. The fixing is done on the support by 2 screws (not supplied).
Support condensateur
Remplit bien son rôle pour fixer des condos diamètre 65, mais un poil trop cher pour un support en plastique...
MUNDORF TUBECAP Capacitor 550V 200μF These capacitors combine high dielectric strength with low residual inductance. They have been developed to offer a high quality alternative to high voltage electrochemical...
Mundorf Tubecap
Comme son nom l'indique idéal pour les amplis à tubes, une alternative qualitative aux électrolytiques
Romain P.
Le meilleur!
Dans un système dépassant les 10.000€, preamp tube Lampizator (lukazs fikus), un Pass fist watt 3 et une paire de Davis nikita 3.0, c'est vraiment le meilleur!
Je l'ai comparé à des câbles à 4 chiffres dont je me tairais de les citer...
Il est aussi bien meilleur que le 3103 que je possède toujours, ce dernier rajoute des harmoniques, il est doux et musical, mais il a un manque évident de transparence comparé au 3082.
C'est en passant sur un système hdg que je m'en suis rendu compte, le 3082 met en lumière aussi bien les qualités que les défauts, donc si vous le trouvez un peu agressif, ce n'est pas lui le coupable, mais bel et bien votre installation.
François D.
Manque fiche de raccordement
J'ai acheté deux modules, mais la documentation sur le raccordement est inexistante. J'ai fait des demandes, j'ai eu des réponses, amis je dois avouer que c'est très succin, sur le module il y a des bornes qui ne servent a tiens et je suis septique sur le raccordement.
Accessoire ultime pour améliorer son système Hifi.
Daniel.B
Après un rodage de 2 jours, j'ai comparé le Viablue NF-75 aux câbles coaxiaux (Real câble AN99 et Canare). Habitué aux qualités sonores de ces 2 câbles, j'ai d'abord pensé que ce nouveau câble ne pourrait faire mieux que les 2 premiers cités. Et là coup de tonnerre! Le viablue les a littéralement cloué sur place. Croyez moi avec 40 années d'expérience de hifi haut de gamme, je me suis dit que mes oreilles ne pouvaient me tromper. Ce qui m'a bluffer tout d'abord c'est la sensation physique des sons. Matérialisation des instruments donnant l'impression qu'ils sont devant vous, respect des silences, image stéréo plus vaste et profonde selon les œuvres musicales. (Classique ou jazz) Apparition de micro informations présentes auparavant, mais qui semble plus palpable maintenant.
En conclusion, je dirais que ce câble Viablue NF75 est une surprise et un enchantement musical à découvrir et à comparer à certaines références. Ce comparatif a été fait à partir d'un lecteur Musical Fidélity et d'un convertisseur Cambridge Dac Magic plus. Système d'écoute Preampli Atoll pr 100 et ampli Ncore Pa 125 le tout sur une paire d'enceinte Dali obéron 3. Un casque Sennheiser HD 595 a été également employé.
Konstantinos A.
Very good dac
Clean and quiet dac with spacious performance and good analysis. Easy to connect in both Windows 10 (with SMSL drivers) and Linux Ubuntu (no drivers needed).
Quick and professional communication and postage from Audiophonics.
Neil M.
a Game changer
I've been a fan of Bruno Putyz and his designs for many years and consider him a pioneer of Class D. Hypex, N-core have been adopted by so many high end manufacturers NAD, Bel Canto etc etc. I was very excited when Purifi announced eigentakt. Even more so when audiophonics packaged it so attractively and affordably for the enthusiast with the well proven Hypex SMPS power supply. An immediate buy. I love building but dont have the machinery or time for nice casework.
Comments. Excellent build quality in and out. If you want pretty spend another 5k.
initially disappointed with sound compared to Nord n core monblocks with hardy discrete amps.
Immediately looked at lm4652 (see other reviews) and replaced with sparkos discrete dual opamps. A revelation. up there with the very best. This is super audiophile at bargain basement prices.
Tres bien. Merci beaucoup.
NM
Neil M.
AUDIOPHONICS HPA-Q400ET 4-channel Class D amplifier Purifi 4x400W 4 Ohm We are proud to present AUDIOPHONICS HPA-SQ00ET, a class D 4 way power amplifier based on 4x PURIFI 1ET400A modules.
a potential game changer
NM
Neil M.
NM
Michel b.
Excellent produit rigide et bien doublé. Par contre la découpe est vraie ment difficile même avec de bon outils. La colle auto adhésive encrasse très vite la lame du cutter ou les ciseaux.
Le moins compliqué est de couper au cutter la partie tissée et aux ciseaux le reste tout en prévoyant d’éliminer régulièrement les résidus de colle.
La colle adhère vraiment bien et la plaque est quasiment impossible à repositionner ou à plier pour la passer par des ouvertures étroites.
jean michel G.
J'utilisais une soudure avec qui je n'étais pas vraiment satisfait. Avec celui la, c'est propre et pas besoin de chauffer éternellement.
Produit à recommander.
Olivier M.
trés bien
voir les autres avis, rien redire.
Installation facile et trés bon son
Christophe V.
Une Tuerie!
Pour avoir eu l’ancienne prise version rhodium sans le traitement NCF pendant plusieurs années, j’ai décidé de passer sur cette version NCF qui je dois dire l’enterre littéralement sur les points de référence telle que la finesse,la clarté sur les voix font un bon en avant de façon considérable, écoute beaucoup plus naturel sans aucune sensation de coloration qui pouvait être un peu la critique de l’ancienne version...
Le grave est plus détouré avec une belle extension sans caricature.
Petit conseil, tout amélioration d’un système haute fidélité devrait déjà commencer par cette prise avant de toucher à autre chose
Une référence !!
François L.
Mitigé
L'histoire des câbles de liaison est trop complexe pour en donner un vrai avis objectif, pour ma part sur mon système, grave trop mou, médium plus doux, aigu en retrait, ah si le saint graal Audio existait ,serions nous un peu moins "idiotphile" ?
Par contre Audiophonics, toujours au top pour leur réactivité et
des réponses SAV avec intérêt.
François L.
bien
Le service Audiophonics au top de réactivité, pour l'article en lui même, rien à dire en particulier, conforme au attente.
Serge P.
PTFE Sheath AWG14 Ø1.5mm Transparent This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 1.5mm diameter maximum. Transparent, it leaves the conductor visible.
Sert aussi de liner cable
En plus de l'usage en électronique , c'est top aussi comme liner cable pour le dérailleur arrière où le trou de passage sur la base est vraiment petit sur le Wilier GTR Team ;-)
Ludovic L.
Je ne suis pas un pro de la soudure et j’ai réussi à monter mes câbles. C’est plus simple que sur les REAN NEUTRIK. Elles sembles solides et les matériaux de qualité, elles tiennent bien une fois branchée, parfait avec le câble CANARE S G6.
Ludovic L.
J’avoue avoir acheter ce câble par curiosité. J’avais un câble enceintes audio-pro en 2x4mm qui convenait bien à mon ancien ampli (Yamaha A-s 701), j’ai récemment acheté un NAD c368, j’étais alors un peu déçu du résultat et je pensais que l’ampli était la caïques du problème. Après le montage des câbles, c’est un changement intégral du son, complètement débouché....beaucoup plus transparent, clair et ça descend plus bas et les aigus plus cristallin sans fatigue. Top quoi...
gilbert d.
Potentiomètre mono
Produit de qualité correspond à mes besoins
gilbert d.
Récepteur audio bluetooth
Produit conforme mes attentes très bon son sur chaîne hifi ainsi qu'une très bonne transaction
Cable très neutre (testé avec Audio-GD R1). Kingwa est vraiment très fort pour proposer d'excellents produits à des tarifs raisonnables. Je recommande ce cable.
