Pour ibasso dx340
Arvydas V.
A
Mohammed B.
Im Vergleich zu Mundorf...
Jani R.
AUDIOPHONICS Trigger Cable Male USB-A to Mono Male Jack 3.5mm 1m Extremely practical, this USB-A to Jack 3.5mm mono trigger cable, assembled in France in our workshops, lets you control the automatic switching of your devices using the 5V...
Just works
I looked for a product like this for years and haven't seen anyone else sell one.
Affordable AVRs don't have trigger outs but they often have a USB port. Arendal Subwoofers need a trigger signal to wake up and stay on at low levels.
This cable is the solution and it works great. I just wish there were options for longer cables and 90-degree USB-connectors.
Philippe L.
Utilisé pour relier un laptop HP de 10 ans d'age à mon tout récent Eversolo DMP-A8 via sa prise OTG: reconnaissance et mise en liaison immédiate entre les appareils, transfert de 2 répertoires HiRes de 1.4 et 0.9Go en moins d'1 minute et sans accroc ! Perso, je préfère utiliser le câble physique plutôt qu'un protocole Samba.
Philippe L.
Raffinement sonore
Utilisé sur un AKG Q701 en remplacement de l'original, le Furutech est un câble souple, bien construit et de longueur idéale, en écoute comparative, les détails sont bien présents dans une scène sonore mieux maîtrisée. Je recommande.
Harry H.
very good solder
I was looking for a premium quality silver solder, (before I used WBT silver solder, easy flowing but less pure then Oyaide)
I think this is one of the best, as their tin quality is better than any other solder and their silver content is high.
Used it to solder Neotech rectangular UP-OCC silver interconnect and the sound is very good.
Bert D.
TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Black Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a...
It works
It works and the sound is perfect. The only thing is that it does make little noises when changing programs on my computer. Its not disturbing. If I start Roon there are some noises when its opening.
Pierre G.
Beau et bon
Très satisfait de cet appareil qui vient remplacer avantageusement un Micromega trio CD qui m’a lâché après près de 30 ans de bons et loyaux services.
Il est très beau, sonne très bien dès la sortie de la boîte et de mieux en mieux en quelques jours.
La fonction lecture de CD ne pose aucun problème mais j’ai trouvé le processus de lecture des fichiers externes à partir de l’entrée USB plutôt difficile à mettre en oeuvre à partir de l’application Eddict Player sur mon téléphone. Toutefois, une fois le processus compris, le résultat est très satisfaisant, équivalent à la lecture directe des CD ou par l’intermédiaire d’Audirvana.
Quant à la fonction Bluetooth (lecture des radios ou des bonnes vidéos de YouTube à partir du téléphone ou d’une tablette), sa sonorité est bluffante avec le codec LDAC.
Je suis ravi de cet achat et je remercie l’équipe d’Audiophonics pour le choix proposé et l’efficacité du traitement des commandes.
David T.
Super produit Simracing
J'ai pris ce produit pour un fauteuil de Simracing, ces enceintes sont très efficaces,.
Bravo aussi pour le délai de livraison malgré le réappro.
je conseille le produit et le site.
Jacques T.
Belle alimentation
J ai acheter cette alimentation pour couper un boucle de masse et surtout pour alimenter correctement un mini PC dédié a l'audio.
Le résultat est la...plus de boucle de masse. Mon système est devenu parfaitement silencieux et les alimentation du pc rien avoir c est propre et silencieux.Le 5V des ports USB et maintenant bien régulé.
isolation galvanique et alim linéaire parfaitement régulee..c est la base du silence
Florent P.
Extraction directe au format DSD 2.8Mbits des SACD sur optique/coax à condition de le coupler avec une carte additionelle
Pour ceux qui n'ont pas d entrée HDMI sur leur DAC, j ai couplé ce dispositif au module additionel Interface / DAC ES9038Q2M I2S vers SPDIF / RCA vendu chez audiophonics également (https://www.audiophonics.fr/fr/modules-interfaces/module-interface-dac-es9038q2m-i2s-vers-spdif-rca-p-17046.html) via le connecteur I2S fourni. Résultats : flux DSD 2.8Mbits reconnu par mon DAC Teac UD701N depuis un lecteur blueray Sony UBP X500. Prévoir 2 alim 12V (https://www.audiophonics.fr/fr/adaptateurs-secteur/ifi-audio-ipower-mk2-adaptateur-secteur-alimentation-audio-faible-bruit-12v-18a-p-15500.html) pour alimenter le module. Parfait
Pedro Fernando P.
Service efficace, livré dans un délai acceptable.
Quant aux câbles que j'ai achetés, au vu de leurs performances, le chapitre des câbles de haut-parleurs dans ma chaîne hi-fi est clos.
Jean-Marie C.
Puissance et droiture au rendez-vous, simplicité d'utilisation, design, que demander de mieux à ce prix !
Bernard B.
Fabrication particulièrement soignée et bien conçue. Réalisation et esthétique quasi luxueuses pour ce petit adaptateur. Fonctionnement Parfait ! aucune dégradation constatée lors de l'écoute. Certes un peu cher, mais par ailleurs, introuvable en 6.35 M/4.4 F. Parfait pour mes casques Sivga et Sendy.
Erik J.
Great warmth to the sound
A softer type of cable really like it to some systems, no signs of fatigue or sibilance.
Bass I really good
Fabrice j.
OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary...
completely transcendental deductive stuff
i was somehow inspired by a *zoviet-france* picture...highest recommendation if you're into maniac options or prone to sensitive side-effects...i will ask my japanese friends to make an aroma-diffuser version...seriously, it is the most low cost highly adaptable detail (together with the furutech nano liquid)
thanks to audiophonics people for their excellent prestation, as usual
Jordan R.
Cable secteur au son rond et chaud
J'ai acheté ce câble secteur pour le monter avec des VIBORG VE & VF 502G, en vue de remplacer un "LC-2 EVO" pour calmer les ardeurs d'un Atoll IN300. À ce jour le câble à 120 h, beaucoup parlent de 500 h et plus de rodage pour qu'il donne sont pleins potentielle.
J'ai obtenu le résultat voulu avoir un son plus chaud et plus rond, un beau bas médium et des basses plus présente sans pour autant perdre sur le reste. À voir dans le temps le résultat final.
Jordan R.
Rapport Qualité Prix au rendez-vous
Excellent câble, belle qualité de fabrication, utilisation de connecteur haut de gamme. Ce câble RJ45 rivalise avec des câbles de grande marque bien plus chère. Bande passante très étendue, on obtient de beaux timbres.
Un petit sac par câble ce n'est pas très utile, mais le packaging est là sans réel impact sur le prix.
Christian M.
AUNE SC1 Clock 10MHz OCXO Sine Signal / Square Signal Silver The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1 frequency synthesizer designed...
Indispensable!
J'ai déjà laissé un avis très positif sur l'horloge Aune SC1 noir que j'ai acheté en Décembre 2023....tellement content que j'ai acheté une seconde horloge Aune en silver pour mon second système....c'est dire! A signaler qu'il ne faut jamais débrancher l'horloge...elle met très longtemps à retrouver son optimum....et si vous pouvez l'alimenter avec une alimentation extérieur de qualité, c'est encore meilleur!
L'Aune silver est branchée sur mon second Teac ud701n, mais je l'ai testée aussi sur un Esoteric N-05XD...superbe!!
Sylvain d.
ARYLIC BP50 Preamplifier DAC ES9023P Bluetooth 5.2 aptX HD aptX Adaptive 24bit 192kHz Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
Génial
Parfaite musicalité à tous points de vue. Ne démérite pas mê dans un système haut de gamme. Seul problème: l'appli ne reconnait pas mon
Francois L.
1MII LAVAUDIO DS200 PRO Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Black The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution...
Super son ! pas déçu du tout !
Son d’enfer. Je redécouvre mes morceaux et albums MP3 320Kb
+ Plus de coupure ou de saut de la connexion (Bluetooth 5.0) et plus de ralentissement bizarres pouvant survenir pendant l'ecoute
Heureux !
Mahé P.
FIIO K7 BT DAC Headphone Amplifier 2x AK4493S THX AAA-788+ 32bit 384kHz DSD256 Bluetooth 5.1 LDAC AptX HD FiiO's K7 BT is a high performance  desktop DAC and Headphone Amplifier combo , demonstrating an exemplary design for an audio reproduction marked by great transparency,...
Volume résolu
Le problème de volume mentionné précedemment était du à un réglage du Bluetooth sur Android. Il a suffit de désactiver le "controle de volume absolu" dans les options bluetooth, pour retrouver un niveau normal. La connexion en USB n'est pas affectée. Je suis pleinement satisfait et corrige ma note à la hausse.
Mahé P.
Volume trop faible en Line Out / Pre-amp
Dommage, car le son me semble bon. Le réglage du gain H/L n'a aucun effect audible dans la configuration testée.
Systeme testé:
- Input: Bluetooth (Kobuz Hi-res + LDAC)
- Output: Line Out et Pre
- Amp: Audiophonics MPA S250NC (2x250W !)
- Speakers: ELAC DBR62
Autre critique: ces petits leviers "mécaniques" de sélection OUT / Gain m'avaient attiré avant l'achat mais ils sont en fait un peu ridicules car tout petits et pas tres pratiques.
Bref, deux étoiles en moins qui ne touchent pas au coeur du travail (DAC), que je suis bien incapable de juger. Peut-etre que c'est un excellent ampli casque...
Anton P.
AUNE AR5000 Open-back Dynamic Headphone Ø50mm 28Ω 108dB 5Hz-41Khz Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm. Thanks to its innovative driver, high-tilt acoustic...
Fucking Amazin
I love these headphones.
Ligthweight, good build quality, amazing soundstage and neutral tuning. For me its the spirital successor to the HD600
Janis P.
Allo Shanti
Significant sonic upgrade to any Hi-Fi gear.
Matthew S.
[GRADE S] Power Jack DC 5.5 / 2.5mm Connector Gold Plated (Unit) Refurbished product - Grade S This 5.5/2.5mm DC Jack power plug with gold-plated copper contact will allow you to create your own power cables with DC Jack connector. Gold...
Inexpensive Option
Very small, low profile plugs. These would be good in non-critical applications. The positive can accept up to 16awg wire. There is not a great place to solder the ground side, so a little dexterity is needed. I wouldn't recommend trying to use wire larger than 18awg. 16awg can be used (depending on insulation thickness) if you bore out the back of the plastic shell, but I wouldn't recommend it. Overall, the price makes them worth a shot since there's little to lose. It's nice to have options available in addition to the more expensive (but better) Oyaide & Elec Audio plugs.
Radek P.
Jirka Vopicka
Looks like
great, small size is advantage, high performance and amazing sound. Best buy.
Sebastian J.
Works perfectly. I use this cable to trigger my HPA-S250NC Power Amplifier from the USB-A output of a Minidsp SHD. Very convenient solution.
jean R.
AiYIMA A07 MAX en 2 Blocs Mono
J'utilise deux amplis A7 MAX configurés en Mono pour une écoute stéréophonique (L&R). Le résultat est très intéressant, très musical et très précis. L'image stéréophonique est bien plus claire. Aucune distorsion d'intermodulation. Bel équilibre spectral. Il faut au moins les alimenter avec une alimentation de 42 Volts DC pour avoir une puissance raisonnable sous 8 Ohms. Voilà. Bravo pour ce petit condensé technologique remarquable qui dépasse un Accuphase E305 appartenant à une autre génération. Prochaine étape : remplacer les AOP NE5532 par des Analog Devices ! (Tout à fait réalisable)
Denis S.
Pour avoir une dizaine de paires câbles enceintes différentes marques, eh bien ceux-là font le job aussi bien et cinq fois moins cher. Très bon produit.
Didier V.
DAYTON AUDIO UM12-22 Ultimax DVC Speaker Driver Subwoofer 600W 2x2 Ohm 87dB 20Hz - 1000Hz Ø30cm Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Discover the best price-to-market ratio!...
Efficace et très fiable
Cela fait 3 ans que j'ai monté deux UM12-22 dans leurs caissons de 66 litres en clos pour compléter mes Genelec 8040 (coupure à 80 Hz entre les deux avec un filtre actif). La cible étant l'écoute de musique et le home cinéma. Les Dayton sont alimentés par un ampli de deux fois 1200W et il faut ça pour les faire bouger puissamment en mode cinéma. Ils ne descendent pas aussi bas que par le calcul, 40 Hz au lieu de 34 Hz mais une fois dans la pièce d'écoute la fréquence de coupure basse approche les 20 Hz et je n'ai donc pas été obligé de compenser le niveau tel que je l'avais imaginé au début. Donc au final, oui ça cogne bien et c'est très propre, aucun effet de résonance désagréable ou sourde. Attention toutefois avec de gros caissons comme cela, il est fortement recommandé d'équaliser la courbe de réponse pour la linéariser en fonction de votre pièce d'écoute.
Francis C.
Peu rigide
Panneaux acier dessus/dessous peu rigides et non solidarisés des façades. Obligation de fixer le tout à l'aide de cornières alu vissées. Dommage, l'esthétique est impeccable à l'extérieur.
Jan S.
My first HDMI cable
I didn't now what to expect but this cable sounds really good. Pangea deliveries a good I2S cable. Like it!
Jan S.
It sounds analogue!
The U18 deliveries. It's a perfect match to R26. After approximately 20hours I deliver calm and precision. It sounds analogue. Happy with this product.
Thomas B.
MATRIX ELEMENT P2 Power Amplifier Class D Stereo 2x230W / Mono 1x850W 4 Ohm Continuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly with the other models in this...
I‘ve bought this small Amp via Audiophonics, shipping was very fast with DPD to Germany even in the season with a lot of snow. This little Amp is a jewel in sound and it is well fabricated and my perfect fit to my also new Matrix Audio Element X2 Pure. This combo replaces a old Class A Setup to save space and to be more „wife“ friendly. I could recommend Audiophonics with a unbeatable price offer and Matrix Audio. It‘s perfect for a small high end Audio setup. Enjoy the sound and the optics
Rene C.
RAMM AUDIO ELITE 8 RCA Cables OCC Copper Cryo Gold Plated 1m (Pair) RAMM Audio Elite8 cables offer an exceptional design quality, using only high quality materials for a perfect transmission of the audio signal and a transparent, pure and...
Fabulous performance for the money
After 240 hours burn-in though Hagerman Audio Labs, Frybaby 3 device, is the cable ready to perform.
It replace my old Ecosse The Maestro (7N) rca cable and beats it in all aspect.
I´m happy and pleased, that I choose this version.
The next level is a good bit more difficult to integral into a system, if you believe the given recommendations / opinions, which I have no doubt to quest, to dispute.
Remi B.
Câble basique
Les connecteurs et les contacts sont OK pour le prix ils s'insèrent bien dans les connecteurs. Mon appreciation tient compte du prix ce n'est pas un câble pro avec une structure star Quad comme un Mogami ou Van Damme mais entre des enceintes actives et une console il fait son job et relève légèrement les graves
Laurent N.
Étonnant
Vraiment étonnant le son sort de cette petite boîte D'accord je n'utilise pas l'alimentation fournie mais une alimentation audiophonics LPSU250 pourtant je pilote des JBL L65 Jubal pas facile a driver...alimenter par un très bon DAC ça fait des merveilles en Bluetooth également il y a moins de niveau forcément merci Audiophonics toujours au top sur le service et en plus vous pouvez trouver des connecteurs WAGO très efficaces pour raccorder vos fils d’enceintes
Laurent D.
Bon appareil : Très joli son pour des formats étendus
Acheté pour écouter la musique numérique de mon ordinateur au bureau avec un ampli de puissance + enceinte il fait parfaitement son travail avec une sonorité chaleureuse, détaillée pour des formats étendus. En PCM aucun soucis, les 32 bits 768 kHz couvrent largement mes besoins, le son est fluide et agréable. Par contre en DSD natif, et j'ai appris que c'est inhérent à ce format, avec ma configuration initiale je perdais la modulation du son qui reste à 100% et ai du intercaler un pré-ampli analogique pour ne pas ébranler les murs (et exploser mes enceintes)
Valence M.
Audiophonics RJ45 Ethernet Cable
Beautifully made cable, so impressed with the attention to detail. The appropriate sheathing matches the quality of this cable. Incidentally, in terms of sound quality, it has opened up the mid-range vocals where previously there was a slight masking of vocal rendition. I will purchase more lengths in the coming weeks.
Ruud N.
Design élégant
Le CD Transport Shanling ET3 est arrivé en quelques jours, le colis était très bien emballé et est arrivé en bon état. Le transport de CD est joli, simple et élégant avec une belle apparence.
Il me reste encore beaucoup de choses à comprendre, car la disposition des menus n'est pas intuitive, notamment la configuration du réseau WiFi a demandé pas mal d'efforts. De plus, l'ET3 sonne bien, bel achat, j'en suis très content
Répartiteur de haute qualité pour enceinte sur 2 amplificateurs.
Très content de ce petit boitier que je partage avec une paire d'enceinte principal, un ampli Hifi , et un ampli HC.
La sélection sur l'interrupteur de ce petit boitier est génial. Moyen facile de changer les entrées sans avoir à déplacer les connexions des haut-parleurs. C'est vrais que cela peut paraitre un peu cher mais quel facilité simple et efficace.
Pour ma part j'ai trouvé le son un peu criard sur mon système, mais je m'y attendais, car j'ai le même problème pour avoir déjà eu l'occasion de mettre en tests des câbles sources ou d'alimentation en placage argent !
Comme le boitier en aluminium est d'une grand facilité de démontage, (8 vis) , et que j'adore bricoler) , j'ai juste changé les 12 petits câbles interne de 13cm +/- en argent, par les même câbles que mes enceintes à l'ampli (en 4mm OFC) ainsi que 24 cosses à sertir (jaune 2.5 à 6 mm²), et le tour est joué. Les son est quasi à l'identique comme avant. Que du bonheur :)))
Merci à Audiophonics pour l'emballage très correcte, et la rapidité de l'envoie en Belgique (4 jours). A très bientôt.
Didier T.
Moyennement satisfait
Fonctionnellement ça fait le job, cependant le joint torique ne sert à rien car il est en périphérie. Pour moi il aurait été plus judicieux de mettre du caoutchouc sur la face du dessous, ce que j'ai fait. Bon rapport qualité prix cependant.
Didier T.
Très bon achat
Mon ampli KORA 90 SI était équipé de 12AT7 de la marque E-H depuis 3 ans. Soient ils étaient rincé soient pas terrible. Et bien là le changement est rude, j'ai retrouvé le spectre et toute la vie musicale que j'avais progressivement perdu sans m'en rendre compte. J'ai eu une réponse très rapide quand j'ai demandé conseil. Pour conclure, un excellent investissement.
Harry H.
Pure silver contact connectors
Nice plugs, I was looking for plugs with pure silver contacts to solder on my Neotech Nemoi rectangular silver cable.
Was a good job, only the screw part at the tail is with one connector not entirely good.
Vukašin J.
Mute problem
Mute circuit have problem in one chanel, or maybe slight delay..
I have no complaints about the sound
Vukašin J.
SABAJ A20D 2022 DAC ES9038Pro Headphone Amplifier TPA6120A2 XMOS XU216 Bluetooth 5.0 32bit 768kHz DSD512 MQA The Sabaj A20d DAC is back in an improved and redesigned 2022 version. Its digital/analog conversion stage is based on an ESS ES9038Pro DAC chip, a high-end DAC supporting high...
Input prolems
There is recognition problem with USB input, one must restart player after input change..
Sabaj provide me new fw, after flashing only USB working..
I have no complaints about the sound..
Vukašin J.
Good
There is light hiss, but only noticeable few inches from tweeter..
Tried with nokia, iphone and raspberry pi charger, same kind of noise..
Alain R.
GD007 Thermal Paste Syringe High performance 3g This gray thermal paste improves the thermal conductivity between a heating component and an associated radiator in order to improve heat dissipation. It has a density...
Excellente pâte therminique
Je l'utilise pour coupler thermiquement des transistors type BC550, montés en différentiel. Un peu de pâte entre eux, une gaine thermo autour pour maintenir les deux transistors ensemble. Le couplage thermique est parfait.
Comme toutes les pâtes thermique, elle est très adhérente et tache les habits. Attention lors de sa manipulation.
Alain R.
Produit qualitatif
J'utilise cet inter partout. Ca donne un même look à mes réalisations, sur façade alu noire. Le cercle bleu, pas trop lumineux est magnifique. Il alimente directement les préamplis ou autres appareils peu puissants. Pour les amplis, cet inter pilote un gros relai 30A avec la bobine en 230V.
david c.
Pleinement satisfait
J'utilise ce câble pour joindre un ampli Marrantz PM7000N à des Focal Aria 906 et c'est un bonheur à écouter
fais le job
Pour le prix aucun reproche possible ; bonne écoute .
