Speaker Driver Midbass 50W 8 Ohm Ø 15cm
For all types of Hi-Fi uses, bass-reflex speakers, 2-way library or Appolito speakers.
Product type | Midbass Speaker Driver |
Impédance | 8 Ohm |
Resonant frequency (fs) | 33Hz |
Max frequency response | f3-5000kHz |
Cutoff frequency (fmax) | 3500Hz |
Max power | 100W Max |
ROMS power | 50W RMS |
Sound pressure (1W/1m) | 89dB |
Surround compliance (Cms) | 1.22mm/N |
Mobile mass (Mms) | 16g |
Mechanical resistance (Rms) | 1.6kg/s |
Mechanical quality (Qms) | 2.02 |
Electronic quality (Qes) | 0.23 |
Total quality (Qts) | 0.21 |
Air mass equivalent volume (Vas) | 36l |
DC Resistance (Re) | 6.5 Ohm |
Coil inductance (Le) | 1.1mH |
Coil diameter | 120mm |
Coil support | Aluminium |
Coil height | 15mm |
Entrefer height | 15mm |
Max linear excursion (Xmax) | +- 3.5mm |
Emitting surface (Sd) | 137cm² |
Displaced air volume (Vd) | 48cm3 |
Force factor (Bl) | 9.7Tm |
Reference efficiency (No) | 0.5% |
Magnet diameter | 120mm |
Magnet weight | 836g |
Cutout diameter | Ø 142mm |
Depth | 89mm |
Dimensions | Ø 165mm |
Weight | 2.32kg |
Bass Reflex | > 10l |
Speaker Power (W RMS) | 50.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 150.0 |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | 89.0 |
Max Linear Excursion (Xmax) (mm) | 3.5 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 5000 |
