MONACOR SPH-210 Hi-Fi Midrange Speaker 19cm 100W 8Ω
Monacor SPH-210
842
77,10 €tax incl.
64,25 € tax excl.
Available
Shipping date: 23-02-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Hi-Fi, 100 W MAX , 8 Ω Hi-Fi Bass Loudspeaker
Loudspeaker for any type of use as bass and low-mid in 2 or 3-way speakers and as a replacement for older speaker models.
Klang + Ton 6/01
"It's always amazing how well the MONACOR INTERNATIONAL speakers are positioned in the competition.
Impedance (Z) 8 Ω
Resonance frequency (fs) 28 Hz
Maximum bandwidth f3-4000 Hz
Freq. cut. (fmax). 3500 Hz
Maximum power 100 W MAX
Rated power (P) RMS = 50 RMS
Pressure sound. (1W / 1m) 90 dB
Compliance susp. (Cms) 1.32 mm / N
Moving mass (Mms) 24.5 kg
Mechanical resistance (Rms) 2.0 kg / s
Mechanical overvoltage. (Qms) 2.14
Electrical overvoltage (Qes) 0.27
Fact. total surge (Qts) 0.24
Volume equ. (VAS) 81 l
DC resistance. (Re) 6.5 Ω
Inductance coil. (The) 1.0 mH
Coil diameter 35.5mm
Coil holder Alu
Height winding 15 mm
Air gap height 8 mm
year>
Linear Excursion (X MAX ) ± 3.5 mm
Transmitting surface (Sd)style = "font-family: Verdana; font-size: small;"> 210 cm 2
Flight. air displaced (Vd) 73.5 cm 3
Force factor (BxL) 10.3 Tm
Ref. (No) 0.6%
Magnet diameter 120 mm
g src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" /> Magnet Weight 29.5 oz.
cutting Ø 183 mm
Mounting depth 99 mm
Dimensions Ø 210 mm
Weight 2.42 kg
n>
Recommended Min Volume
closed rc = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" /> 15 l
bass reflex 27 l
Colissimo - TNT - SoColissimo
