MONACOR SPH-115 Speaker Driver Midbass 50W 8 Ohm 87dB
Monacor SPH-115
Reference : 1929
43,90 €tax incl.
36,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Bass-midrange speaker, 80 W MAX, 8 Ω
Specially coated paper membrane, rubber suspension, the ideal speaker for 2-way library, satellite or Appolito systems, close load or bass-reflex.
blank.gifImpedance (Z) blank.gif8 Ω
blank.gifResonance frequency (fs) blank.gif65 Hz
blank.gifMaximum bandwidth blank.giff3-8000 Hz
blank.gifFreq. cut. (Fmax). blank.gif4500 Hz
blank.gifMaximum power blank.gif80 WMAX
blank.gifNominal power (P) blank.gif50 WRMS
blank.gifPressure sound. (1W / 1m) blank.gif87 dB
blank.gifCompliance susp. (Cms) blank.gif1.33 mm / N
blank.gifMovable mass (Mms) blank.gif4.5 g
blank.gifMechanical resistance (Rms) blank.gif0.8 kg / s
blank.gifMechanical overvoltage. (Qms) blank.gif2.23
blank.gifElectrical overvoltage (Qes) blank.gif0.47
blank.gifFact. total overvoltage (Qts) blank.gif0.39
blank.gifVolume equ. (VAS) blank.gif5.5 l
blank.gifDC resistance. (Re) blank.gif5.8 Ω
blank.gifInductance coil. (The) blank.gif0.3 mH
blank.gifCoil diameter blank.gif25 mm
blank.gifCoil support blank.gifAlu
blank.gifHeight of winding blank.gif9 mm
blank.gifHeight gap blank.gif6 mm
blank.gifLinear Excursion (X MAX)blank.gif ± 1.5 mm
blank.gifTransmitting surface (Sd) blank.gif55 cm2
blank.gifFlight. air displaced (Vd) 8.3 cm3
blank.gifForce factor (BxL) blank.gif4.8 Tm
blank.gifRef. (No) blank.gif0.3%
blank.gifMagnet diameter blank.gif72 mm
blank.gifMagnet weight blank.gif8 oz.
blank.gifcutting blank.gifØ 101 mm
blank.gifMounting depth blank.gif58 mm
blank.gifdimensions blank.gif115 x 115 mm
blank.gifWeight blank.gif0.65 kg
blank.gifclosed blank.gif2.5 l
blank.gifbass reflex blank.gif5.5 l
Speaker Power (W RMS)50.0
Speaker TypeMidbass
Impedance (Ω)8
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)1.5
Highest frequency (Hz)8000
équipe les iguana
Odyssée Acoustic utilise ces HP dans leur enceintes Iguana que je possède depuis 2012.
en tweeter un DT-99 également de chez Monacor accompagne ces bas médium.
le tout est vendu 1200€/l'unité
This review has been posted for MONACOR SPH-115 Speaker Driver Midbass 50W 8 Ohm 87dB
