MONACOR MS-130 Loudspeaker Medium 8 ohm Ø13cm (Unit)
Monacor MS-130 Midrange Loudspeaker 8 ohm Ø 5" (Unit)
Reference : 1205
39,50 €tax incl.
32,92 € tax excl.
Available
Shipping date: 23-05-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
8 Ω midrange speaker, Hi-Fi
Inverted suspension, mobile coil on high temperature kapton support, low moving mass for optimum impulse behavior.
This speaker is a classic of the German designer. An expressive and articulate medium sound with a performance of 94dB, ideal for the design of three-way speaker.
c = "http://www.monacor.de/global_img/blank.gif" alt = "" width = "10" height = "1" /> Impedance (Z) 8 Ω
Resonance frequency (fs) 120 Hz
Maximum bandwidth fx-8000 Hz
Maximum power 250 W MAX (400-5000 Hz)
Rated power (P) 40 W RMS
Average sound pressure (1 W / 1 m) 94 dB
Compliance susp. (Cms) 0.44 mm / N
Moving mass (Mms) 4 g
Mechanical overvoltage. (Qms) 5.23
Electrical overvoltage (Qes) 1.06
Fact. total surge (Qts) 0.88
Volume equ. (VAS) 3 l
DC resistance. (Re) 6.1 Ω
Force factor (BxL) 4.2 Tm
Inductance coil (The) 0.25 mH
Coil diameter 25.5 mm
Coil holder Kapton
Linear Excursion (X MAX ) ± 0.7 mm
<img src = "http://www.monacor.de/global_img/blank.gif" alt = "" width = "10" height = "1" /> Transmitting surface (Sd) 70 cm 2
Magnet Weight 17.7 oz.
Weight 1.3 kg
[Img-20536-left-thickbox_default]
[Img-20537-left-thickbox_default]
monacor MS-130
Speaker TypeMédium
Impédance8 Ohm
Diamétre Haut Parleur (cm)130
MenbranePapier
Rendement94
Colissimo - TNT - SoColissimo
