MONACOR SPH-130AL Speaker Driver Midbass 50W 8 Ohm 88dB Ø15.5cm
Monacor SPH-130AL
Reference : 830
69,90 €tax incl.
58,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
Hi-Fi, 100 W MAX , 8Ω Bass-Loudspeaker
Aluminum diaphragm and dust cover, highly dynamic, high bandwidth, for High End speakers, for example. An ideal loudspeaker for small speakers.
 Impedance (Z) 8 Ω
 Resonance frequency (fs) 48 Hz
 Maximum bandwidth f3-4500 Hz
 Maximum power 100 W MAX
 Rated power (P) 50 W RMS
 Average sound pressure (1 W / 1 m) 88 dB
 Compliance susp. (Cms) 1.2 mm / N
 Moving mass (Mms) 9 g
 Mechanical overvoltage. (Qms) 5.07
 Electrical overvoltage (Qes) 0.34
Fact. total surge (Qts)0.32
 Volume equ. (VAS) 10.8 l
  </ Font>
 DC resistance. (Re) 6.4 Ω
 Force factor (BxL) 7.22 Tm
 Inductance coil (The) 0.6 mH
 Coil diameter 25 mm
 Coil holder Kapton
 Linear Excursion (X MAX ) ± 2.3 mm
 Transmitting surface (Sd) 80 cm 2
 Magnet Weight 15.6 oz.
 Weight 1 kg
PDF-Download
PDF-Download
Speaker Power (W RMS)50.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm).0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)2.3
Lowest frequency (Hz)N/A
Highest frequency (Hz)4500
