MONACOR SPH-165CP HiFi 120W / 8Ω low-midrange speaker
Monacor SPH-165CP
835
119,00 €tax incl.
99,17 € tax excl.
Available
Shipping date: 23-02-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Carbon fiber diaphragm speakers, core decompression hole; their characteristics in bass and mediums are amazing.
120 W MAX , 8 Ω Hi-Fi bass-loudspeaker
Large 50 mm coil, with exceptional bass response, for high-power 3-way loudspeakers and 2-way loudspeaker enclosures.
Impedance (Z)8 Ω
<strong> Resonance frequency (fs)30 Hz
Maximum bandwidthf3-6000 Hz
Freq. cut. (fmax).3500 Hz
Maximum power120 W MAX
Rated power (P)80 W RMS
Pressure sound. (1W / 1m)89 dB
Compliance susp. (Cms)1.71 mm / N
Moving mass (Mms)17 g
Mechanical resistance (Rms)0.7 kg / s
Mechanical overvoltage. (Qms)4.85
Electrical overvoltage (Qes)0.33
Fact. total surge (Qts)0.31
Volume equ. (VAS)38 l
DC resistance. (Re)6 Ω
Inductance coil. (The)0, 7 mH
Coil diameter50 mm
Coil holderglass fibers
Height winding17.5 mm
Air gap height8 mm
Linear Excursion (X MAX )± 4.75 mm
<img src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" />
Transmitting surface (Sd)127 cm 2
Flight. air displaced (Vd)60.3 cm 3
Force factor (BxL)7.6 Tm
Ref. (No)0.3%
Magnet diameter120 mm
Magnet Weight 29.5 + 1.76 oz.
cuttingØ 142 mm
Mounting depth90 mm
Dimensions165 x 165 mm
Weight2.5 kg
Recommended Min Volume
closed9 l
bass reflex20 l
PDF-Download
PDF-Download
Colissimo - TNT - SoColissimo
