Monacor SPH-170C
Monacor SPH-170C
Reference : 1184
88,10 €tax incl.
73,42 € tax excl.
Series of subwoofers and low-medium Hi-Fi made with the utmost care and an elegant design. Aluminum bowl, carbon fiber membrane, deep bass.
120 W Max , 8 Ω,
very wide diaphragm, very little distortion allowing natural restitution; well suited for use as a bass-medium loudspeaker in 2-way systems, requiring a low volume.
blank.gif Impedance (Z) blank.gif 8 Ω
blank.gif Fresonance frequency (fs) blank.gif 38 Hz
blank.gif Maximum bandwidth blank.gif f3-3500 Hz
blank.gif Maximum power blank.gif 120 W MAX
blank.gif Rated power (P) blank.gif 60 W RMS
blank.gif Average sound pressure (1 W / 1 m) blank.gif 88 dB
blank.gif Compliance susp. (Cms) blank.gif 1.06 mm / N
blank.gif Moving mass (Mms) blank.gif 16.43 g
blank.gif Mechanical overvoltage. (Qms) blank.gif 7.22
blank.gif </ Font> blank.gif
blank.gif Electrical overvoltage (Qes) blank.gif 0.27
blank.gif Fact. total surge (Qts) blank.gif 0.26
blank.gif Volume equ. (VAS) blank.gif 24 l
blank.gif DC resistance. (Re) blank.gif 6 Ω
blank.gif Force factor (BxL) blank.gif 9.44 Tm
blank.gif Inductance coil (The) blank.gif </ Font> 0.8 mH
blank.gif Coil diameter blank.gif 37 mm
blank.gif Coil holderblank.gif Kapton
blank.gif Linear Excursion (X MAX ) blank.gif ± 4 mm
blank.gif Transmitting surface (Sd) blank.gif 127 cm 2
blank.gif Magnet Weight blank.gif 21 oz
Colissimo - TNT - SoColissimo
