MONACOR SPH-200CTC Speaker Driver Subwoofer Dual Coil 2x60W 2x8 Ohm 88dB
Monacor SPH-200CTC (Double bobine)
Reference : 1932
115,00 €tax incl.
95,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Subwoofer Speaker, 2 x 100 WMAX, 2 x 8 Ω
Movable coil, molded aluminum bowl, reinforced carbon fiber membrane, ideal for low space.
blank.gifImpedance (Z) blank.gif2 x 8 Ω
blank.gifResonance frequency (fs) blank.gif22 Hz
blank.gifMaximum bandwidthblank.giff3-4000 Hz
blank.gifFreq. cut. (F max.) blank.gif3500 Hz
blank.gifMaximum powerblank.gif2 x 100 WMAX
blank.gifRated power (P)blank.gif2 x 60 WRMS
blank.gifPressure sound. (1W / 1m)blank.gif88 dB
blank.gifCompliance susp. (Cms)blank.gif1.16 mm / N
blank.gifMoving mass (Mms)blank.gif45 g
blank.gifMechanical resistance (Rms) blank.gif1.1 kg / s
blank.gifMechanical overvoltage. (Qms) blank.gif4.91
blank.gifElectrical overvoltage (Qes) blank.gif0.23
blank.gifFact. total surge (Qts)blank.gif0.22
blank.gifVolume equ. (VAS) blank.gif75l
blank.gifDC resistance. (Re) blank.gif2 x 6.8 Ω / 3.4 Ω
blank.gifInductance coil. (The)blank.gif2 x 1.0 mH / 1.0 mH
blank.gifCoil diameter blank.gif50 mm
blank.gifCoil holderblank.gifKapton
blank.gifHeight windingblank.gif15.5 mm
blank.gifAir gap heightblank.gif8 mm
blank.gifLinear excursion (X MAX)blank.gif± 3.75 mm
blank.gifTransmitting surface (Sd) blank.gif214 cm2
blank.gifFlight. air displaced (Vd) blank.gif80.3 cm3
blank.gifForce factor (BxL)blank.gif9 Tm
blank.gifRef. (No) blank.gif0.5%
blank.gifMagnet diameter blank.gif120 mm
blank.gifMagnet Weightblank.gif29.5 oz.
blank.gifCutting blank.gifØ 181 mm
blank.gifMounting depthblank.gif115 mm
blank.gifDimensionsblank.gifØ 211 mm
blank.gifWeightblank.gif2.8 kg
blank.gifclosedblank.gif-
blank.gifbass reflexblank.gif20 l
Speaker Power (W RMS)60.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)250.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)3.7
Lowest frequency (Hz)N/A
Highest frequency (Hz)4000
