MONACOR SPH-225C Speaker Driver Woofer 120W 8 Ohm 90dB
Monacor SPH-225C
Reference : 853
195,00 €tax incl.
162,50 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Series of subwoofers and low-medium Hi-Fi made with the utmost care and elegant design. Aluminum bowl, carbon fiber membrane, deep bass.
Bass speaker, 150 W MAX , 8 Ω,
high-rigidity and wide-travel diaphragm with very little distortion to achieve deep bass in Hi-Fi systems and small subwoofers; is well suited for use as a mid-bass loudspeaker in 2-way systems, requiring very small cabinetry.
Impedance (Z)
8 Ω
Resonance frequency (fs)
39 Hz
Maximum bandwidth
f3-3000 Hz
Maximum power
150 W MAX
Rated power (P)
100 W RMS
Average sound pressure (1 W / 1 m)
90 dB
Compliance susp. (Cms)
0.43 mm / N
Moving mass (Mms)
36.6 g
Mechanical overvoltage. (Qms)
4.94
Electrical overvoltage (Qes)
0.31
Fact. total surge (Qts)
0.30
Volume equ. (VAS)
24 l
DC resistance. (Re)
5.9 Ω
Force factor (BxL)
13.17 Tm
Inductance coil (The)
0.8 mH
Coil diameter
50 mm
Coil holder
Kapton
Linear Excursion (X MAX )
± 6 mm
Transmitting surface (Sd)
201 cm 2
 Magnet Weight
38 oz.
Speaker Power (W RMS)120.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)222.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)3000
