Monacor SPH-135KEP
Monacor SPH-135KEP
90,00 €tax incl.
75,00 € tax excl.
Hi-Fi, 80 W MAX , 8 Ω Bass-Stereo Speaker
Kevlar membrane and pole piece, an extra medium, in library systems, also as low-resonance low-bass, beyond 200 Hz however an optimum sound source for the entire range of voices.
Impedance (Z)
8 Ω
Resonance frequency (fs) 45 Hz
Maximum bandwidth f3-10,000 Hz
Maximum power 80 W MAX
Rated power (P) 50 W RMS
Average sound pressure (1 W / 1 m) 89 dB
Compliance susp. (Cms) 1.23 mm / N
Moving mass (Mms) 10 g
Mechanical overvoltage. (Qms) </ Span> 5.54
Electrical overvoltage (Qes) 0.32
Fact. total surge (Qts) 0.30
Volume equ. (VAS) <img src = "" alt = "" width = "10" height = "1" /> 15.5 l
DC resistance. (Re) 6 Ω
Force factor (BxL) 7.5 Tm
Inductance bobbin (The) 0.75 mH
Coil diameter 35.5 mm
Coil holder Kapton
</ Span>
Linear Excursion (X MAX ) ± 3.25 mm
Transmitting surface (Sd) 95 cm 2
Magnet Weight 17.7 ± 0.6 oz.
Weight 1.52 kg
PDF Download
PDF Download
Colissimo - TNT - SoColissimo
J'en ai commandé une paire afin de remplacer les hp (Focal double bobines) dans mes enceintes Confluence. Résultat dépassant mes espérances! Ces SPH-135KEP sont très bons!
This review has been posted for Monacor SPH-135KEP
