MONACOR SPH-200KE Speaker Driver Midbass 80W 8 Ohm 90dB
Reference : 841
129,00 €tax incl.
107,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
120 W MAX , 8 Ω Hi-Fi Midrange Subwoofer
Kevlar fiber diaphragm, molded aluminum bowl, for 2 or 3 way systems. A recognized HP with broadband usage and bass playback in dazzling Hi-Fi.
 Impedance (Z) 8 Ω
 Resonance frequency (fs) 28 Hz
 Maximum bandwidth f3-4500 Hz
 Maximum power 120 W MAX
 Rated power (P) 80 W RMS
 Average sound pressure (1 W / 1 m) 90 dB
 Compliance susp. (Cms) 0.89 mm / N
 Moving mass (Mms) 37 g
 Mechanical overvoltage. (Qms) 4.65
 Electrical overvoltage (Qes) 0.41
 Fact. total surge (Qts) 0.38
 Volume equ. (VAS) 54 l
 DC resistance. (Re) 6.2 Ω
 Force factor (BxL) 9.9 Tm
 Inductance coil (The) 0.75 mH
  Coil diameter50 mm
 Coil holder Kapton
 Linear Excursion (X MAX ) ± 4.75 mm
 Transmitting surface (Sd) 207 cm 2
 Magnet Weight 29.5 + 1.76 oz.
 Weight 2.8 kg
Speaker Power (W RMS)80.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)200.0
Diaphragm typeKevlar
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)4.7
Lowest frequency (Hz)N/A
Highest frequency (Hz)4500
2 reviews
Perfect chassis
I bought them a couple of weeks ago and now inserted them into my speakers. They do a fantastic job!
This review has been posted for MONACOR SPH-200KE Speaker Driver Midbass 80W 8 Ohm 90dB
excellent hp en utilisation large bande comme il est preconisé. le resultat est phenomenal et le rapport qualite/prix imbattable.
