Monacor SPH-200KE
Monacor SPH-200KE
841
99,00 €tax incl.
82,50 € tax excl.
120 W MAX , 8 Ω Hi-Fi Midrange Subwoofer
Kevlar fiber diaphragm, molded aluminum bowl, for 2 or 3 way systems. A recognized HP with broadband usage and bass playback in dazzling Hi-Fi.
blank.gif Impedance (Z) blank.gif 8 Ω
blank.gif Resonance frequency (fs) blank.gif 28 Hz
blank.gif Maximum bandwidth blank.giff3-4500 Hz
blank.gif Maximum power blank.gif 120 W MAX
blank.gif Rated power (P) blank.gif 80 W RMS
blank.gif Average sound pressure (1 W / 1 m) blank.gif 90 dB
blank.gif Compliance susp. (Cms) blank.gif 0.89 mm / N
blank.gif Moving mass (Mms) blank.gif 37 g
blank.gif Mechanical overvoltage. (Qms) blank.gif 4.65
blank.gif Electrical overvoltage (Qes) blank.gif 0.41
blank.gif Fact. total surge (Qts)blank.gif 0.38
blank.gif Volume equ. (VAS) blank.gif 54 l
blank.gif DC resistance. (Re) blank.gif 6.2 Ω
blank.gif Force factor (BxL) blank.gif 9.9 Tm
blank.gif Inductance coil (The) blank.gif 0.75 mH
Coil diameter blank.gif 50 mm
blank.gif Coil holder blank.gif Kapton
blank.gif Linear Excursion (X MAX ) blank.gif ± 4.75 mm
blank.gif Transmitting surface (Sd) blank.gif 207 cm 2
blank.gif Magnet Weight blank.gif 29.5 + 1.76 oz.
<img height = "1" src = "http://www.monacor.com/global_img/blank.gif" width = "10" alt = "blank.gif" /> blank.gif
blank.gif Weight blank.gif 2.8 kg
PDF-Download
PDF-Download
Colissimo - TNT - SoColissimo
excellent hp en utilisation large bande comme il est preconisé. le resultat est phenomenal et le rapport qualite/prix imbattable.
This review has been posted for Monacor SPH-200KE
