MONACOR SPH-300KE Speaker Driver Woofer Kevlar 120W 8 Ohm 90dB
Monacor SPH-300KE
Reference : 858
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
High quality Kevlar diaphragm speakers for extreme deep bass and midrange applications.
200 W MAX , 8 Ω Hi-Fi bass driver
Kevlar fiber diaphragm, long-stroke molded aluminum bowl, for 3-way systems, close or bass-reflex. For all types of Hi-Fi and high-end uses.
 Impedance (Z) 8 Ω
 Resonance Frequencye (fs) 22 Hz
 Maximum bandwidth f3-2200 Hz
 Maximum power 200 W MAX
 Rated power (P) 120 W RMS
 Average sound pressure (1 W / 1 m) 90 dB
 Compliance susp. (Cms) 0.81 mm / N
 Moving mass (Mms) 65 g
 Mechanical overvoltage. (Qms) 4.15
 Electrical overvoltage (Qes) 0.36
 Fact. total surge (Qts)  0.33
 Volume equ. (VAS) 250 l
 DC resistance. (Re) 6.2 Ω
 Force factor (BxL) 12.5 Tm
 Inductance coil (The) 1.5 mH
 Coil diameter 65.5 mm
 Coil holder glass fibers
 Linear Excursion (X MAX ) ± 6.5 mm
 Transmitting surface (Sd) 496 cm 2
 Magnet Weight 42.7 ± 2.8 oz.
 Weight 5.4 kg
Speaker Power (W RMS)120.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)300.0
Diaphragm typeKevlar
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)6.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)2200
