MONACOR DT-250 Speaker Driver Dome Tweeter 50W 8 Ohm 90dB Ø25mm
Monacor DT-250 Dome Tweeter 8 Ohm Ø25mm
Reference : 1221
51,90 €tax incl.
43,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
Hi-Fi Dome Shaker, 100 W MAX , 8 Ω
Titanium alloy, excellent attenuation thanks to the rubber suspension, absence of resonances typically metallic, pleasant sound image and transparent; its square shape predisposes it to use in Hi-Fi.
Impedance (Z) 8 Ω
Resonance frequency (fs)1.7 kHz
Maximum bandwidthfx-25 kHz
Cut-off frequency (12 dB)3 kHz
</ Span>
Maximum power100 W MAX
Nominal power50 W RMS
Average sound pressure (1 W / 1 m)90 dB
Coil diameter25 mm
Magnet diameter72 mm
</ Span>cuttingØ 74 mm
Mounting depth26 mm
Dimensions116 x 86 mm
Weight
[Img-20522-left-thickbox_default]
[Img-20523-left-thickbox_default]
Speaker Power (W RMS)50.0
Speaker TypeDome tweeter
Impedance (Ω)8
Loudspeaker diameter (mm)25.0
Diaphragm typeTitanium
Efficiency / Sensitivity (dB)90.0
Highest frequency (Hz)25000
