VAN DEN HUL FLEXICON B4 Balanced Modulation Cable Silver Plated OFC Copper 2x 0.205mm² Ø3.7mm
VAN DEN HUL FLEXICON B4 Balanced Wiring Cable Silver Plated OFC Copper 0.205mm² Ø3.7mm
In 1990, a large recording studio in South Africa contacted Van Den Hul to design and produce a high performance cabling wire that could meet the strictest professional requirements. The result was Flexicon B4, a high quality cable combining very low conductor-to-conductor capacitance, high shielding factor and high flexibility. Flexicon B4 is ideally suited for balanced internal wiring of HiFi and professional audio equipment.
Reference : 16257
9,50 €tax incl.
7,92 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Câble vendu au mètre
Van Den Hul Flexicon B4
Balanced Wiring Cable Silver Plated OFC Copper 2x 0.205mm² Ø3.7mm
Van Den Hul Flexicon B4 Fil de Câblage Symétrique Cuivre OFC Plaqué Argent 0.205mm² Ø3.7mm
In 1990, a large recording studio in South Africa contacted Van Den Hul to design and produce a high performance cabling wire that could meet the strictest professional requirements. The result was Flexicon B4, a high quality cable combining very low conductor-to-conductor capacitance, high shielding factor and high flexibility. Flexicon B4 is ideally suited for balanced internal wiring of HiFi and professional audio equipment. The Flexicon B4 has two silver plated OFC copper strands with a cross section of 0.205mm². Each conductor is insulated with a polypropylene sheath. The double shielding is made of a dense helix of 48 strands of 0.12mm with underneath a reinforced aluminum foil specially treated and presenting a resistance of 2.85Ω/100m. Finally, the white outer jacket is made of Hulliflex®, a material with superior properties compared to PCV and giving the cable a long life without aging effects.
Product typeWiring cable
Conductors materialOFC Copper
Conductors platingSilver
Section2x 0.205mm² (24AWG)
InsulationPolypropylene
Shielding48x 0.12mm strands helix
Reinforced aluminum foil
Shielding resistance2.85Ω/100m
External sheathHulliflex®
External diameterØ3.7mm
ColorWhite
Diameter (mm)3.7
Number of conductors2
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)0.205
Ground / ShieldingYes
In 1990, a large recording studio in South Africa contacted Van Den Hul to design and produce a high performance cabling wire that could meet the...
