Capacitor 600V 47µF
Mundorf TubeCap capacitors are made from a Polypropylene film with special features. It is particularly thin and self-healing. This allows TubeCap capacitors to achieve a higher maximum operating voltage with rather compact dimensions.
These capacitors combine high dielectric strength with low residual inductance. They have been developed to offer a high quality alternative to high voltage electrochemical capacitors and are therefore ideal for use in tube amplifiers.
Product type | Capacitor |
Capacity | 47µF |
Voltage | 600VDC |
Tolerance | ±5 |
ESR @ 10Hz | 7mΩ |
ESL @ 500kHz | 24.5nH |
Dielectric | Polypropylene (PP) |
Loss factor | tan ∂ < 0.005 @ 1kHz |
Failure rate | 1 fit |
Sealing compound | PU UL 94-V0 |
Useful life | 100000h @ hot spot 60°C |
Cover | 0.5 x Un ; 40° |
Max ambient temperature | 85°C (185°F) |
Dimensions | Ø45 x 57mm |
Wires diameter | 1.5mm |
Wires spacing | 27.5mm |
Tolerance (%) | 5.0 |
Capacitor capacitance | 47 |
Rated voltage (V) | 600.0 |
Capacitor type | Film capacitor |
Capacitor format | Radial |
