ALLO DIGIONE PLAYER Network audio Player Raspberry Pi 3B+ Digital interface DigiOne Pre-installed Volumio Black
Player DigiOne pré-monté et pré-installé Volumio - Boîtier noir
This item is a digital player with network support. That is, it is able to play audio tracks from a remote source. This source may be a hard drive located within the network or even an online streaming service.
3.8 / 5
Reference : 12714
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
DIGIONE NETWORK PLAYER RASPBERRY PI & SOFTWARE VOLUMIO
High Performance Digital Player
network player with volumio and raspberry pu
Play your audio files without going through a computer
With no screen and no control interface, this DigiOne player can be remotely controlled from a mobile phone, tablet or any device that can run an internet browser. A way to enjoy a high quality audio playback without having to leave the sofa or bath.
Raspberry Pi 3B
Raspberry Pi, an ideal base for an audio player
This player works from an Raspberry Pi 3 B+ (single board computer / mini-computer) SBC. This mini computer is equipped with ideal capacities for audiophile use with its 4-core 1.2Ghz processor, its comfortable 1GB RAM and its high performance network connectivity (wifi, bluetooth) installed natively.
Despite its small size, this device has all the capabilities to play high quality audio files, including the most demanding audiophile formats in terms of computing power and memory.
Interface DigiOne S/PDIF
The Raspberry Pi card is equipped with a DigiOne digital interface. This high-performance digital audio module is renowned in the audiophile world for its excellent price / quality ratio. It extends the capabilities of the Raspberry card and allows it to exit the digital audio stream via a BNC output and an RCA output.
With its two internal clocks, the DigiOne interface offers a remarkably clean signal as evidenced by its extremely low jitter rate of 0.4 picosecond. The jitter is taken up by all the elements of the chain and difficult to erase at the cost of new inaccuracies of the signal, this feature makes the DigiOne an ideal choice for a high fidelity digital player.
Interface digitale DigiOne S/PDIF Allo
Dedicated audio player
DigiOne Allo monté sur Raspberry Pi dans boîtier
Used in a high fidelity channel, this type of network reader is extremely practical since it is infinitely more compact than a conventional computer and thus limits the space occupied. Wireless connectivity is also useful for reducing congestion related to cable buildup. Reciprocally, all of its computational power and computer construction are mobilized in the service of audio quality. The sound quality will be multiplied compared to a smartphone or a conventional tablet.
Thus, your devices dedicated to communication and work avoid being solicited for a precarious audio use and remain available for their other functions: no more the phone that rings in the middle of an opera or the computer that makes an update during a guitar solo. The network player for its part only fulfills an audio function and therefore have no pretext to disrupt the listening.
VOLUMIO, great audio software preinstalled.
Volumio lecteur audio raspberry pi
Unlike many network drives based on a Raspberry Pi type SBC, this DigiOne player is already equipped with preinstalled audio software. It is therefore not necessary to have skills in installation under linux or micro-SD card flashing. The device is ready to use, it will just connect to your network to enjoy the full extent of its capabilities.
Volumio is a software developed for the sake of providing a high-performance interface from an audio point of view while remaining as comfortable and intuitive to use as any other consumer solution. This software exploits all the hardware capabilities of the Raspberry Pi, especially its connectivity since it offers the ability to control the player from any device that can connect to a web browser (computer, smartphone, tablet or even other SBC ... etc.). It is therefore very simple to choose a music, to change the reading options, the sound volume from anywhere as long as the connection to the network exists.
To go even further and extend the capabilities of the device, Volumio is also able to manage a wifi hotspot. That is to say to establish an ad hoc network if the fixed network is missing. This means that the unit will still be able to play your audio library even if your router / box fails. On the other hand, it also means that this network drive can be moved for use in private network locations (joint benefit to its very small size).
Open Source and freedom of choice
The tradition of the SBC is singularly articulated around the notion of open source. Devices and software solutions compatible with Raspberry Pi are no exception, so you can easily change the software installed on your network drive if you want to experiment with other softwares or other functions.
Max2Play dietpi
This network player will work just as well with Max2Play, DietPi or Picoreplayer depending on your audio projects. It will be enough to extract the micro-SD card and to flash it with the software image of your choice.
Typenetwork Player
Raspberry Pi version3B+
ProcessorBroadcom BCM2837
4 core 1.2 Ghz
memory1GB
portsMaterialized: 4x USB / RJ45 1x / 1x HDMI
Dematerialized: Wifi / Bluetooth
GPUVideoCore IV
digital interfaceHat Allo Digione
ExitsS / PDIF Coaxial BNC & RCA
galvanic isolationYes
Noise50uV
oscillators2x NDK
jitterMinimal 0.411 ps
Power Supply5V (Power Supply ALLO included)
CaseBlack (black spacers and screws)
InputWiFi
OutputBNC
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rateNC
Interface chipNC
4 reviews
Très décu
La photo met le produit extrement bien en valeur. Vous recevrez une boite mal finie qui ne fait pas du tout bonne impression. Passons, elle sera cachée.
J'ai passé 2h à essayer de la faire fonctionner mais le logiciel inclus ne fonctionne pas. Il faut tout formater et réinstaller. Que de temps et d'argent perdu !
Bonjour,
Ce problème est extrêmement rare.
Le SAV vous aurait proposé une image neuve sur simple demande.
Réécrire une image ne prends au maximum qu'une dizaine de minutes.
This review has been posted for ALLO DIGIONE PLAYER Network audio Player Raspberry Pi 3B+ Digital interface DigiOne Pre-installed Volumio Black
Lien pratique et performant entre numerique et analogique ; indispensable.
= mini-pc dédié au son ; très très pratique, ne bouffe que très peu de ressources lorsqu'il est commandé par un autre ordi. Ca fait longtemps que j'attendais un tel produit! Une lecture du son impeccable. Dans ce cas, installation uniquement sur le reseau local, à parir du routeur (la box par exemple).
Possiblité d'utilisation comme lecteur seul, je pense, mais non testé. Dans ce cas, il faut evidemment relier un ecran, clavier et souris. Ce que j'ai du faire dans mon cas pour l'installation car le nom d'utilisateur fourni par la notice ne fonctionne pas; donc obligé de passer par le N°IP attribué par le routeur. Rien de compliqué. Coté sécurité, le ssh a maintenant été désactivé, et ne reste plus aucun souci ; bien penser à changer les codes d'acces (root et l'utilsateur par défaut "volumio"). Alimentation (de seulement 5V!) à brancher sur l'ampli si possible, sinon, effectivement pas d'interrupteur on/off.
Conclusion ; indispensable pour toute personne qui souhaite lire très facilement, proprement et à long terme des formats numériques sur une installation hifi sensible.
bonne surprise
Très bon produit, je lui mets 4/5 car je n'ai aucune valeur de comparaison étant néophite en la matière. Bref après un conseil du support d'Audiophonics j'ai opté pour ce produit, qui pour le prix en fait beaucoup je trouve, l'installation est des plus simples, et le son est top ( après avoir laissé passer quelques heures de rodage) . Pour Audiophonics, la livraison a été très rapide comme dab. Merci.
Bon lecteur réseau
Le DigiOne Player est un très bon lecteur audio, coté son je n'ai rien à lui reprocher. La solution intégrée avec Volumio fonctionne très bien, il y a juste à brancher et a écouter ... Aujourd'hui c'est important d'avoir une solution hardware et software évolutive et OpenSource pour ne pas être bloqué avec des lecteurs réseaux beaucoup plus chers bridés sur certains services (spotify, Tidal, ...)
Le seul reproche que je peux faire à ce lecteur c'est la gestion de l'arrêt et surtout du redémarrage car il n'y a pas de bouton On/Off sur le boitier.
Mon deuxième reproche concerne plutôt Volumio, c'est une super solution mais coté sécurité ils sont un peu dans le rouge ... mais bon tout cela n’enlève rien à la qualité du son.
Coté AudioPhonics, c'est parfait des conseils avisés et un support à l'écoute, la livraison parfaite aussi.
Bonne écoute à tous
This item is a digital player with network support. That is, it is able to play audio tracks from a remote source. This source may be a hard drive...
