ALLO DIGIONE SIGNATURE Network audio Player Raspberry 3B+ DigiOne interface Pre-installed DietPi Black
ALLO DIGIONE PLAYER Network audio Player Raspberry 3B+ DigiOne interface Pre-installed Volumio Aluminum Casing Black
By buying this product you get 35 loyalty points
Reference : 13479
359,00 €tax incl.
299,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
NETWORK PLAYER Digione SIGNATURE RASPBERRY PI 3B + & SOFTWARE DietPi
High performance digital network drive
acrylic-case-for-digione-signature (3)sq
Access your audio files without a computer
This element is a digital player with network support. That is to say it is capable of playing audio tracks from a remote source. This source may be a hard drive located within the network or even an online streaming service.
Without any screen nor interface, Digione reader is controlled remotely with a mobile phone, tablet or any device capable of running a web browser. One can therefore enjoy a high quality audio playback without having to leave the couch or the bath.
Digione Interface Signature
The Allo Digione interfaces are currently the best digital SPDIF outputs to Raspberry Pi. They connect directly to a Raspberry Pi by GPIO and provide digital transfer while correcting jitter characteristic of a bare SBC.
This interface provides a BNC 75 Ohm output and RCA Coaxial Digital 24bit 192khz output. The rise time is 1 ns and the voltage completely meets the coaxial / BNC standards (550mV coaxial). This interface is capable of transforming a limited digital source such as Raspberry Pi into a true high-fidelity device with a remarkably low jitter of 400fs.
This is the latest version SIGNATURE Digione. The latter is divided into two parts isolated from each other (galvanic) operated with two power supplies to optimize the audio signal and avoid any pollution of the digital streams. It gets latest version of the NDK oscilateurs ultra low jitter noise . The audio circuitry also hosts a supercapacitor.
Raspberry Pi + 3B, ever more effective for a network drive
This modernized version of the player operates a SBC (single board computer / mini computer) Raspberry Pi release 3B +. This mini computer and audio platform retains all its qualities and even gaining performance through an extensive network connectivity (WiFi 802.11b / g / n / ac and 300mbps Ethernet).
Despite its small size, this device has every capability to play audio files of high quality, including the most demanding audiophile formats in terms of computing power and memory. This modernized version benefits in addition to improved stability and access to the fastest network.
dedicated music player
Used in high fidelity chain, this type of network drive is extremely convenient since it is much more compact than a conventional computer and thus limits the space occupied. Wireless connectivity is also useful for the purpose of reducing congestion related to the accumulation of cables. Conversely, all of the computing power and its IT construction are mobilized in the service of audio quality. The sound quality will be multiplied compared to a smartphone or tablet classic.
So your devices dedicated to communication and work to avoid being solicités precarious audio use and are available for their other functions over the phone ringing in the middle of an opera or a computer that is updated during a guitar solo. The network drive for its part fulfills an audio function and will have no excuse to disturb listening.
DietPi, Software preinstalled Advanced Audio
Digione player signing DietPi
Caution: Basic computer knowledge is required to use DietPi. If you are looking for a simple software, the same hardware is available with Volumio (way easier for neophytes) by following this link.
Unlike many network drives based on an SBC Raspberry Pi type, this Digione drive is already equipped with a preinstalled audio software. After the SBC is set up, your network drive will enjoy the full extent of its capabilities.
DietPi is a software developed in an effort to offer a deep configurable interface, versatile and able to offer great audio performance that can compete with any mainstream solution. This software exploits all the hardware capabilities of the Raspberry Pi while offering many opportunities to accommodate the software and hardware changes that the user is likely to bring.
Open source and free to choose
The tradition of the SBC is particularly articulated around the concept of open source. Devices and software solutions compatible with Raspberry Pi are no exception to the rule so you can easily change the software installed on your network drive if you happen to wish to experience other softwares or other functions.
This network drive will work just as well with Max2Play, Volumio or Picoreplayer suit your audio projects. It will suffice to extract the micro-SD card and flash the firmware image with your choice.
Typenetwork Player
Version Raspberry P3B +
ProcessorBroadcom BCM2837B0
4 hearts 1.4 Ghz
memory1GB
portsMaterialized: 4x USB / RJ45 1x / 1x HDMI
Dematerialized: Wifi 802.11 b / g / n / ac / Bluetooth 4.2
GPUVideoCore IV
digital interfaceAllo Digione SIGNATURE
ExitsS / PDIF Coaxial BNC &
galvanic isolationYes
Noise50uV
oscillators2x NDK
jitterminimal 400fs
Power Supply5V (PI)
5-6V (Digione Signature) 100ma Min
HousingAcrylic
AccessoriesCard 8GB e.MMC
Parts supplied
Raspberry Pix1
Digione Signaturex1
Black Acrylic Casex1
8GB microSDx1
alimentaion 5Vx1
DC cable - USB-Cx2
InputMicro SD
InputRJ45
OutputCoaxial SPDIF
OutputBNC
Max sampling rate192kHz
Download
DigiOne-Signature-Tech-Manual
DigiOne-Signature-Tech-Manual_en
Download (4.47M)
