AURALIC ARIES G1 HiFi Streamer 32bit 384kHz DSD512 DLNA / UPnP AirPlay Bluetooth
The Aries G1, new to Auralic, is a high-end network drive with incredible performance and features. Between its exceptional versatility, its carefully selected components and its Tesla G2 data processing platform, the Aries G1 is a network drive that will not leave you indifferent.
4.7 / 5
By buying this product you get 239 loyalty points
Reference : 13190
2 399,00 €tax incl.
1 999,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the Auralic Aries G1.1.
Auralic Aries G1
HiFi Streamer 32bit 384kHz DSD512 DLNA / UPnP Airplay Bluetooth
Auralic Aries G1 Lecteur Réseau
4 years after the release of the first Aries, this High-End network player is evolving with a real update: the Aries G1 streamer and interface! Taking advantage of Auralic's technologies and know-how, the Aries G1 connects to your network or digital sources such as network storage, online streaming services such as Qobuz or Spotify, web radios and USB devices to provide you high-performance remote playback. Playlists, caching, stable playback, multi-room bit-perfect are just some of the features Auralic offers on its devices, and with support for Qobuz Sublime+, Spotify Connect and Roon Ready, Aries G1 connectivity is more extensive than ever. The hardware and component enhancements of the Aries G1 allow Auralic's new device to deliver stunning performance, making it a perfect choice for streaming high resolutions up to DSD512 and PCM 384kHz 32bit.
Tesla G2 : Platform made for sound
In 2014 Auralic develops the first Tesla platform with the goal of creating a high-performance, upgradable system optimized for high sound quality. Working hand in hand with their control interface and innovative features, it was the most powerful data processing platform for digital music playback and streaming.
Now comes the Tesla G2 platform. 50% faster with double the resources for data processing, the Tesla G2 is the engine behind the sound excellence of the G2 line.
Arualic Aries G1 plateforme Tesla G2
37500 MIPS
Processing speed
The Tesla G2 CPU is 50% faster than the Tesla G1 processor.
200%
Memory & Storage
Twice the system memory and data storage means fluid audio signal processing and advanced features.
1GB
Memory Cache
A huge cache memory reduces network noise and drastically lowers circuit opening time for better sound quality.
Auralic Aries G2 Lightning OS
High-end audio streaming in all its glory
The Aries G1 uses Lightning OS which brings many innovations to bring your music to life. Extensive cache memory, multi-room functionality and the ability to create playlists allow you to explore all your audio sources in high resolution. Take control with applications like Lightning DS or Roon and meet the true audiophile streaming.
A beautiful screen
The Auralic Aries G1 is equipped with a sublime 4" (10.16cm) screen, offering beautiful colors with a definition of more than 300ppi for a pleasant and fluid user experience. This screen displays the playback status, device settings, and a view of your entire audio library.
Auralic Aries G2 Affichage
Auralic Aries G2 Applications
Explore new musical horizons
The Aries G1 offers almost universal connectivity to access all your digital sources. Tri-Band Wifi and Ethernet connectivity open your system to UPnP and DLNA media servers, shared network folders, internet streaming services, web radio as well as RoonReady, Bluetooth, Airplay and SongCast.
Auralic Aries G2 Connectique
Dual Femto Clock
With 2 separate and super precise Femto clocks, with a speed in the order of a quadrillionth of a second, you enjoy an extremely low jitter and therefore a better sound reproduction. A clock takes care of the digital outputs and the second of the USB output for an always stable signal.
Smart IR Control
The Smart IR Control system allows you to automatically associate your Auralic and its features with any remote control. Simply tell the device your favorite remote control and each function (play/pause, volume, track selection, etc.) can then be associated with the buttons you choose.
1GB Memory Cache
Open network connections and data recovery are subject to noise that could affect sound quality. The Tesla G2 platform dedicates 1Gb of RAM to caching, reducing open circuits and ultimately improving system sound.
Dual Purer-Power
The first power supply is used to power the data processing circuit, the LCD screen and the internal or USB storage of the Aries G1. The second power supply is used to power sensitive components such as Femto clocks and the USB output. The two power supplies are galvanically isolated from each other to ensure that there is no EMI interference between them.
Active USB
Auralic's second generation of Active USB goes beyond asynchronous USB data control for greater accuracy and reclocking to reduce jitter. The technology also allows bypassing the USB power supply, using its own purer linear power supply instead. This means that the lower quality USB power supply and the resulting EMI noise is kept away from your music.
Auralic Aries G1 double alimentation
Dual Power Supply
Auralic offers its Aries G1 two ultra-quiet linear power supplies, galvanically isolated from each other, always in search of maximum noise reduction for exceptional performance. The data processing and display power supply is completely separate from the power supply used to supply the sensitive components, which therefore have their own power supply. The interference level between the two separate zones is reduced to the strict minimum to make room for your music.
Auralic Aries G1 Test par HiFi Choice
Auralic Aries G1 complete review by HiFi Choice
HiFi Choice magazine presents the Aralic Aries G1 with a complete reviewhighlighting the exceptional qualities of the device as well as its ideal price for the performance offered. An article that ends with a very good score of 5/5 and the Editor's Choice award.
"  The Aries G1 is a beautifully realised streaming platform that delivers the Auralic experience to a variety of DACs at an attractive price. If you have a DAC, this is the most transparent way to add network music streaming to your system and leads the way in this field. "
Read HiFi Choice review
Auralic Aries G1 review by Qobuz
" This Auralic Aries bridge is a device that we enjoyed testing, well made, solid and equipped with a pleasant control application. "
Favourite for the Aries G1 by ON-topaudio
" The Aries G1 knows how to get the most out of all audio files. To be combined with high quality devices that will capitalize on the G1's key capabilities to bring music to life in your living room. A real favorite. "
Coup de cœur pour le Aries G1 par ON-topaudio
Présentation vidéo du Aries G1 par Darko et Auralic
Aries G1 Review byThe Hans Beekhuyzen Channel
Streaming supported formatsLossless : AIFF, ALAC, APE, DIFF, DSF, FLAC, OGG, WAV, WV
Lossy : AAC, MP3, MQA, WMA
Supported sampling ratePCM : Up to 384kHz 32bit *
DSD Up to DSD251 **
Control softwareAuralic Lightning DS for iOS
Auralic Lightning DS for Web Browser (device settings only)
OpenHome compatible control software (BubbleUPnP, Kazoo)
Roon (Roon core required separately)
Streaming inputsNetwork shared folder
USB Storage
UPnP / DLNA Media Server
Native Tidal Streaming and Qobuz Sublime+
Internet radios
AirPlay
Bluetooth
Songcast
RoonReady
Audio outputsDigital : AES/EBU, Coaxial, Toslink
USB : USB Host to compatible DAC ***
NetworkWired : Gigabit Ethernet
Wireless : Wifi 802.11 b/g/n/ac Tri-Band
ConsumptionSleep : < 10W
Playback : 50W max
Dimensions34 x 32 x 8cm
Weight7.2kg
Product finishingMatte Black Anodized Aluminium case
PackageAuralic Aries G1
2x external Wifi antenna
Power cord
User guide
* 352.8KS/s and 384KS/s and 32bit are supported through USB output only.
** Via DoP V1.1 or native DSD protocol.
*** Compatible with DAC devices that don't require Linux driver.
InputWiFi
InputRJ45
OutputOptical Toslink
OutputCoaxial SPDIF
OutputUSB
DAC / ADC ChipNC
Max sampling rate384kHz
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
7 reviews
Excellent product
Excellent streamer with many useful features. The Lightning Os app is responsive. The interface is user friendly. You do require your own DAC for this streamer. There is 20 bands of peq to choose from, 4 different sounding filters too. Very well done!
This review has been posted for AURALIC ARIES G1 HiFi Streamer 32bit 384kHz DSD512 DLNA / UPnP AirPlay Bluetooth
AURALICS ARIES G1
Très bon appareil qui sonne analogique
Beaucoup de sorties numériques
La télécommande ne répond pas très rapidement (essayé sur 2 télécommandes différentes )
Si il y a un problème sur le réseau le lecteur n'étant plus connecté apparemment il n'est même pas utilisable avec un disque dur externe ou une clé USB un défaut qui peut être pénible si le réseau décroche régulièrement.
Avec ce genre d'appareil c'est la fin des lecteur cd/sacd
Très bien
L’Aries mini faisait bien son travail, le G1 me semble un peu meilleur pour les basses, plus d’espace et une sensation de densité très agréable. Meilleur accord avec l’Yggdrasil qui assure le traitement ? Le mini était trop mini, des qu’un câble bougeait il changeait de place sur le DAC où il était posé. Le G1 a une belle présence sans alimentation externe. L’écran fait joli mais est inutile tant l’applicatIon de gestion est parfaite sur Apple. Un très gros regret, pas d’emplacement prévu pour un DD interne, alors que le mini en a un. Ce mini reste un produit extraordinaire en densité de fonctions et en qualité de restitution grâce aussi à la qualité de l’appli Lightning DS. J’ai longuement hésité entre garder le Mini ou prendre ailleurs un matériel avec le DD interne....Protéger le G2 est un choix marketing, c’est il me semble, surtout une erreur marketing. Un G1 avec un DD de 1giga serait à ce prix un matériel irrésistible face à la concurrence, ce n’est pas le cas, dommage....
Jolie machine qui fonctionne bien.
-Acheté pour sa fonction RAAT avec Roon et très facile à mettre en œuvre dans cette config. , j'ai aussi testé la lecture de ma musique (1To) sur mon NAS ainsi que sur un DD externe; j'ai validé ces deux autres options sans problème.
-L'appareil est de belle facture, on peut seulement regretter la surface matte extrêmement salissante et les caractères minuscules du menu de mise en route.
-L'application DS est assez ergonomique, j'aurai aimé pouvoir la lire en français; l'allemand est disponible (grâce à l'importateur européen ?).
-L'application Qobuz est agréablement intégré avec les bios des artistes en français (pas comme sur Roon...).
-Tout c'est bien passé avec Audiophonics et l'appareil est arrivé très bien emballé.
**Je retire une étoile uniquement pour le français absent dans l'application DS (IOS et sur l'interface WEB); je pense que c'est peu de chose à faire surtout en regard du prix de l'unité.
Bonjour,
L'application Lightning DS vient d'être mise à jour. La langue française est maintenant disponible.
AURALIC ARIES G1
Superbe streamer.
Je recherchais un streamer sans dac pour l’associer à mon dac MYTEK BROOKLYN DAC. Je suis ravi de cette association. Au début on se perd un peu dans la multitude de paramètres de réglage, mais on fini très vite par en comprendre la logique et là comme on dit en anglais « enjoy »
The Aries G1, new to Auralic, is a high-end network drive with incredible performance and features. Between its exceptional versatility, its...
