HiFi Streamer ES9018K2M DAC WiFi DLNA AirPlay 32bit 384Khz White
The Auralic Aries Mini is a complete and powerful network drive, integrated into a compact and attractive housing. It will allow you to upgrade your audio system to provide more advanced connectivity and enjoy your audio files more simply and quickly.
The heart of the Aries Mini is its proprietary Auralic Tesla Quad ARM A9 processor running at 1GHz. This one, in charge of data processing and associated with the Auralic Lightning DS OpenHome interface (iOS 8 compatible), allows fast, smooth and extremely efficient navigation and reading.
The digital-to-analog conversion part is handled by a DAC ESS ES9018K2M chip supporting high sampling rates up to 32bit 384kHz in PCM and up to DSD256. This chip uses the 32bit HyperStream architecture and Time Domain Jitter Eliminator technology, giving it a nice dynamic, THD+N of -120dB while significantly reducing jitter.
One of the strengths of the Aries Mini is undoubtedly its connectivity. Indeed, it offers an RJ45 Gigabit port as well as WiFi support, to allow you to access files stored on devices on your local network (computer, NAS, smartphone...). There is also a space to accommodate a 2.5" hard disk (not provided).
The device is also compatible with many streaming services such as Qobuz, Spotify Connect, Tidal and Internet radios. This way you can enjoy your favorite service to listen to your music simply. In addition, the Aries Mini is compatible with DLNA/UPnP and AirPlay protocols to allow you to easily stream your audio files from your smartphone.
On the output side, there is a S/PDIF Coaxial connector, Toslink Optics, stereo RCA and a USB-B 2.0 output to connect an external DAC and give it the advanced connectivity of the Aries Mini.
The performance of the Aries Mini can be increased by using a Auralic PSU optional line power supply. The latter provides better stability of the sound stage and refinement of harmonics in the midrange and treble.
" The Auralic Aries Mini streamer is a modern device that offers a wide range of settings and reading capabilities, resulting in very good sound quality on its analog outputs. "
Product type | Streamer |
Inputs | 1x RJ45 Ethernet Gigabit WiFi Dual Band 1x 2.5" Hard Drive Slot (not included) |
Outputs | USB-A 2.0 for audio DAC 1x S/PDIF Coaxial 1x Optical Toslink 1x Stereo RCA |
Supported sampling rates | USB : up to 32bit 384kHz Coaxial : up to 24bit 192kHz Optical : up to 24bit 96kHz |
Compatible streaming service | Qobuz Spotify Connect Tidal Radios internet AirPlay |
Software interface | Auralic Lightning DS OpenHome, iOS 8 compatible |
Compatible media servers | Minimserver Twonky Asset UPnP Jriver DLNA/UPnP AirPlay |
Supported audio formats | AAC, AIFF, ALAC, APE, DIFF, DSF, FLAC, MP3, OGG, WAV, WV, WMA |
Power supply | Via Jack DC 5.5/2.5mm connector |
Max consumption | 10W |
Dimensions | 135 x 135 x 28mm |
Weight | 500g |
Input | RJ45 |
Input | WiFi |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | RCA |
DAC / ADC Chip | ES9018K2M |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | White |
Color | Other |
