BLUESOUND NODE 3 (2021) Multiroom Streamer WiFi Bluetooth 5.0 24bit 192kHz MQA White
BLUESOUND NODE 3 Multiroom Streamer WiFi Bluetooth 5.0 24bit 192kHz MQA White
The BlueSound Node 3 opens up the world of remote control, network playback, streaming and multi-room. Easily integrated into an existing HiFi system, it will allow you to upgrade your audio setup with new features.
2.0 / 5
By buying this product you get 54 loyalty points
Reference : 15381
549,00 €tax incl.
457,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
BlueSound Node 3 (2021)
BlueSound Node 3Lecteur Réseau Multi-Room WiFi Bluetooth 5.0 24bit 192kHz MQA Blanc
Your audio system, connected and available at all times
The BlueSound Node 3 works as an extremely versatile network player with WiFi, Ethernet and Bluetooth 5.0 connectivity, allowing you to remotely control your music playback from your local network, your favorite streaming app or internet radio once integrated into your audio system. Remote control is simply done via the BluOS application, available on iOS, Android, Windows or Mac.
An incredibly intelligent design
If it is compact, the BlueSound Node 3 is nevertheless a real concentrate of technologies. Underneath its casing is an audiophile digital-to-analog converter that supports not only PCM streams up to 24bit 192kHz, but also MQA for superior listening. With software features such as tone control and the ability to use a fixed level output, you can customize your listening preferences in detail.
Highly versatile
Particularly versatile, the Node 3 can connect via HDMI eARC, WiFi, Bluetooth or host a USB storage device. It also supports AirPlay 2 and Spotify Connect protocols, and is compatible with the Bluetooth aptX HD codec. As a result, the BlueSound Node 3 offers a wide range of integration possibilities within an existing system, adapting to any situation with ease.
Your music throughout the house
The Node 3, with its BluOS application, allows you to simply and remotely control all your connected players. BluOS is currently the only platform capable of supporting up to 64 players while broadcasting at 24bit. In addition, it provides access to a wide range of features and services to suit everyone's needs and desires.
An intuitive and ergonomic interface
The Node 3 incorporates a touch-sensitive surface on the top for accessing the device's basic functions, such as controlling playback or volume level. The Node 3 can also be controlled using a voice assistant such as Siri, Alexa or Google Voice, or even by programming your own IR remote. Advanced controls like tone control or subwoofer crossover optimization are available directly from the BluOS Controller app. Finally, the BlueSound Node 3 can also be connected to Lutron, Elan, RTI, Crestron and other home automation systems.
Multiroom
One of the Node 3's assets is the ease with which it can be used to set up a connected and fully remote-controlled multi-room system. This means you can broadcast your music throughout your home, synchronized or not, with settings easily made from the BluOS interface.
Product typeStreamer
ConnectivityWiFi 5 (802.11ac, 2.4/5GHz)
Ethernet RJ45, GigE 1000Mbps
Bluetooth 5.0 bidirectional
Audio inputs1x Combo Mini-Toslink / Jack 3.5mm
1x HDMI eARC
Audio outputs1x Analog stereo RCA (fixe or variable level)
1x Coaxial
1x Optical Toslink
1x USB-A 2.0 (USB Host)
1x Jack 3.5mm headphone output
1x Subwoofer output (RCA) (network coupling to Pulse Sub+.)
Trigger12V
IR Remote controlIncluded
IR Jack 3.5mm input
Supported file formatsMP3, AAC, WMA, WMA-L, OGG, ALAC, OPUS, WAV, AIFF, MPEG-4 SLS, MQA
CPUARM Cortex-A53 Quad Core, 1.8GHz par coeur
Native sampling rates16-24bit 192kHz
SNR-113dBA
THD+N0.002%
DACNC
OSBluOS
Compatible OSiOS
Android
Windows Vista, 7, 8, 10
Mac OS 10-11
Straming servicesDeezer, Deezer HiFi, Spotify, Qobuz, Tidal, Napstrer, Amazon Music, Web radios...
Others transmission protocolsAirPlay 2
Spotify Connect
Tidal Connect
Roon Ready
Voice controlAmazon Alexa Skills
Actions on Google
Control systemsControl4
Crestron
URC
RTI
ELAN
Lutron
Power supply100-240VAC (cable included)
Dimensions220 x 146 x 46mm
Weight1.09kg
Package1x Bluesound Node 3
1x Power cable
1x Ethernet cable
1x Stereo RCA cable
1x Toslink to Mini-Toslink adapter
InputHDMI
InputOptical Mini-Toslink
InputJack 3.5mm
InputRJ45
InputWiFi
OutputWiFi
OutputOptical Toslink
OutputJack 3.5mm
OutputBluetooth
OutputUSB
OutputSubwoofer
DAC / ADC ChipNC
Max sampling rate192kHz
ColorWhite
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Attention lecteur USB 'has been'
Bon streamer mais interface limitée. La gestion de vos fichiers audio sur support USB (clé ou disque) est tout simplement nul. Donc, si vous avez un grosse collection de fichiers audio passez votre chemin.
This review has been posted for BLUESOUND NODE 3 (2021) Multiroom Streamer WiFi Bluetooth 5.0 24bit 192kHz MQA White
The BlueSound Node 3 opens up the world of remote control, network playback, streaming and multi-room. Easily integrated into an existing HiFi...
