IFI AUDIO ZEN STREAM Hi-Res Audio Streamer WiFi DLNA 32bit 384kHz DSD256 MQA
Behind its modern design, the iFi Audio hides an extremely powerful network player. Its sole purpose: to allow you to stream your music from the Internet to your DAC, without any loss of quality. Hi-Res certified and capable of playing streams up to PCM 32bit 384kHz and DSD256 via WiFi / LAN, you just need to associate a connected device to the Zen Stream to simply enjoy your music.
4.1 / 5
By buying this product you get 39 loyalty points
Reference : 15490
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
iFi Audio Zen Stream
iFi Audio Zen Stream Lecteur Réseau Audio Hi-Res WiFi DLNA 32bit 384kHz DSD256 MQA
Behind its modern design, the iFi Audio hides an extremely powerful network player. Its sole purpose: to allow you to stream your music from the Internet to your DAC, without any loss of quality. Hi-Res certified and capable of playing streams up to PCM 32bit 384kHz and DSD256 via WiFi / LAN, you just need to associate a connected device to the Zen Stream to simply enjoy your music. Its optimized open source architecture offers a particularly wide compatibility and regular updates.
The Zen Stream's architecture incorporates high-quality components in an optimized circuit. These include two SuperSpeed USB 3.0 ports with Active Noise Cancellation II technology, a Coaxial SPDIF output with integrated iPurifier, a power supply using Silent Power technology and a software layer based on Volumio and enhanced and optimized by iFi Audio engineers.
Optimized in every detail
Zen Stream benefits from a particularly well optimized software layer. From the drivers to the kernel and shell, from the applications to the user interface, everything is optimized for smooth and transparent operation and excellent sound performance.
The streamer also offers the possibility to select "exclusive" modes, i.e. individual settings dedicated to specific operating modes in order to offer the purest possible performance. All other programs are disabled in order to minimize software jitter, an often neglected aspect that has a negative impact on the sound quality.
Operating modes
  • All-in-one (AIO) mode : covers all modes
  • DLNA Streaming
  • NAA Streaming
  • Roon Bridge Streaming  (Roon Ready)
  • Tidal Streaming
Versatility at its best
The Zen Stream offers extensive connectivity for maximum versatility:
  • Play directly from Spotify/Tidal using Spotify Connect and Tidal Connect protocols.
  • Works with DLNA certified applications.
  • AirPlay integrated (Chromecast to come in a future update).
  • Compatible with Roon.
  • NAA operation with the Sygnalist HQPlayer software.
Qobuz is only available on iOS via Airplay or on Android via Bubble UpNP.
An exceptional design
Particularly powerful, the Zen Stream is equipped with high-end components and advanced technologies.
  • Quad Core ARM Cortex 64bit processor.
  • USB and SPDIF interfaces regulated by a femtosecond GMT clock to eliminate jitter.
  • Active Noise Cancellation II and iPurifier technologies for USB and SPDIF interfaces
  • Intelligent Ethernet controller with low idle current and low voltage dropout.
  • High precision 1.6MHz synchronous power controller.
  • C0G capacitors, Taiyo Yuden and Murata low ESR coils.
Product typeStreamer
InputsWiFi
Ethernet RJ45
1x USB-A 3.0 (USB Host)
Outputs1x Coaxial SPDIF
1x USB-A 3.0
DSD up to DSD256
MQA
Supply voltage9VDC 1.8A - 15VDC 0.8A
ConsumptionNo signal : ≈6W
Max signal : ≈10W
Dimensions158 x 100 x 35mm
Weight578g
ColorBlack and silver
IFI AUDIO ZEN STREAM Lecteur Réseau Audio Hi-Res WiFi DLNA 32bit 384kHz DSD256 MQA
InputWiFi
InputRJ45
OutputUSB
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsTidal
Streaming services & Network protocolsTidal Connect
8 reviews
Bien optimisé il n a pas de concurant.
Je vous beaucouo de pouces en bas. De critiques trompeuse. Un des avis a le meme probleme rencontré sur mon streamer zen en suisse. Si non l alimentation fournie n est que basique. La programation est simple. Bouton arriere reglé sur all option. Alumer le logiciel ifi local et selectionné vos option. Sorter du mode et tourné a l aide du tourne vis la couche logiciel par ex dlna pour l utilisation avec bubbpnp. Il faut un cable usb de grande qualité type neotech argent ou le must un synergetics researche foundation. L alimentation ifi elite vas super bien ou autre ali de haute qualité. Un rj45 idem argent neotech ou sr. Et la vous avez un flagchip de tres haut vol. Comme tous outils de precision il merite le minimum pour s exprimé.
This review has been posted for IFI AUDIO ZEN STREAM Hi-Res Audio Streamer WiFi DLNA 32bit 384kHz DSD256 MQA
Avis de Paul G totalement faux
Vous pouvez apprécier le produit pour ce qu'il est mais dans la réalité des faits il est parfaitement possible de faire beaucoup mieux pour beaucoup moins cher.
Ce produit n'est qu'un SOC à 50 € dans une boite sans avoir l'évolutivité logiciel et hardware des susnommés "system on a chip"
Sans parler du fait qu'il soit bloqué sur Volumio la seule solution out tout est payant ...
Excellent
Excellent streamer dans un tarif contenu, gagne à y ajouter une alim linéaire. pour faire mieux il faut y mettre beaucoup plus cher.
Excellent
Celà fait quelques années que j’utilise l’environnement Bluesound et j’en suis ravie avec un Node 2i et des amplificateurs NAD. Mais avec l’acquisition d’une paire d’enceinte BC Acoustique Nil, je me disais qu’il manquait un petit quelque chose et après quelques recherches j’ai choisi ce streamer. Et une fois branché sur Ifi Zen One signature, la musique prend une nouvelle dimension, plus large, plus de relief et une sonorité très analogique. Un vrai coup de cœur.
A optimisé pour un exelent resultat
J ai acheté en suisse se model avec des probleme decrit par se messieur. Renvoyé trois fois. Trois fois le meme probleme. Je me suis fait remboursé et je l est acheté chez audiophonicd qui en avais enfin en stock. Aucun probleme. Ali ifi elite 15v. Cable ali oayde pure cuivre 4,5mm carré et prise viborg rhodium chucko et oayde t004 cu berilium pl platine palladium iec. Genial. Description deja faite au dessus.. Mon bonn n8 avec ali elite 5v et ali cable neoteck cui argent et viboeg rhodium. Rj45 neotech Neu cuivre. Bientot argent.. Top fu top. Certe cela enfle le prix. Mais ont arrive a une qualité proche d un g1 auralic. Voir mieux suivant le dac utilisé. Donc a chouchouté un peut pour en retiré la quintessence.. Miam. ????
Behind its modern design, the iFi Audio hides an extremely powerful network player. Its sole purpose: to allow you to stream your music from the...
