RASPTOUCH I-SABRE ES9038Q2M Streamer with Touchscreen and Volume Control
RaspTouch I-Sabre ES9028 - Streamer Touch with Volume Control
By buying this product you get 36 loyalty points
Reference : 12181
365,83 €tax excl.
This product is no longer in stock
RaspTouch ES9038Q2M
Tactile Network Player with Volume Control
RaspTouch ES9028Q2M
The RaspTouch is evolving! Equipped this time with the excellent DAC I-Sabre ES9038Q2M, it offers a significant improvement in terms of ergonomics thanks to volume and source control, an OLED screen, and a Coaxial SPDIF port.
Complete compatibility
Comes with a Micro SD card for OS installation, many operating system choices are available to you, depending on your preferences and needs.
Ready to use electronically, many software solutions exist to meet all your expectations: piCorePlayer, Max2Play, OpenElec...
The Multiroom without any limits
Want to enjoy your music throughout your home? The Rasptouch offers you an efficient multiroom system, allowing you to stream your files to any board connected to your network and control them.
A top-of-the-range audio player with the ES9038Q2M converter
Thanks to Audiophonics I-Sabre ES9038Q2M converter you get a top-of-the-range materialized audio player, accepting resolutions up to..; 32bit / 768kHz and incorporates 32bit Hyperstream II technology that provides a wider dynamic range while drastically reducing jitter and unwanted noise. The DAC also incorporates an ultra-low phase noise clock. Thus, the ES9028Q2M has a THD of 0.002dB and a THD+N of -108dB to offer you new musical horizons.
The 9038Q2M, thanks to an integrated microprocessor and in order to facilitate its use and ensure high stability, detects the source sampling rate and automatically adapts to it. Thus, there is no longer any problem decoding the signal and no artifacts will appear when listening.
Finally, the system offers complete connectivity with 4x USB 2.0 ports, a SPDIF Coax input and an Ethernet RJ45 port for enjoying your music locally or from your network, and a Stereo RCA and HDMI output. You therefore have a panel of connectors to meet most needs.
An advanced analog output
Integrating two NJM 2114 AOPs powered by 12V on the board corresponding to the ESS technical diagrams, the last NJM 2114 AOP in buffer finalizes the analog output stage, to ensure optimal reproduction.
AOP NJM 2114
Complete connectivity
The Rasptouch I-Sabre ES9038Q2M offers a complete connectivity that will suit most needs. Thus you will find 4 USB 2.0 ports and an Ethernet RJ45 port to enjoy your music locally or from your network, and at the output a Stereo RCA, Coaxial RCA and HDMI. You therefore have a panel of connectors to simply enjoy your entire audio library.
Rasptouch ES9028Q2M Connectiques
Rasptouch ES9028Q2M écran
Control & Ergonomy
With its 7" touch screen, you can easily and intuitively control your audio library via a graphical interface. In this version the RaspTouch also includes a volume and source controller. Thus you can, thanks to the button on the upper side adjust the volume but also change the source (I2S or SPDIF) by pressing it. The OLED screen informs you of the volume, active source and sampling rate of the read file.
A sober and elegant design
Mounted in a 100% CNC machined aluminium case in France, its black colour and brushed matt appearance give it a modern and elegant design. It will therefore integrate seamlessly into your high-end audio system.
Rasptouch Boîtier
Qobuz review
Qobuz gives the RaspTouch ES9038Q2M a very nice test! On the program, general overview and listening on the Qobuz application. To read!
test qobuz rasptouch es9028q2m
Connectic : Input
USB-A 2.0x4
Ethernet RJ45x1
Micro SD Slotx1
Coaxial SPDIFx1
Connectic : output
Stereo RCAx1
HDMIx1
Raspberry Pi 3B+
ChipsetBroadcom BCM2837B0
CPUARM Cortex A53 64bit 1.4GHz
Wifi802.11 b/g/n/ac
Bluetooth4.2
Coprocessor multimedia IV Videocore Dual Core-
RAMLPDDR2 1Go
ES9038Q2M
Sample rateUp to 32bits 768kHz
Dynamic range129dB
THD+N-120dB
ManufacturerESS Sabre
Screen and housing
Main screen7" tactile capacitive 800 x 400px
Secondary screenOLED
Volume control / outputYes
Housing materialAluminium
Power supplyJack DC 5.5/2.1mm - 7.5V 2.9A (Included)
AccessoriesMicro SD card, Power supply
InputRJ45
InputUSB-A
InputMicro SD
InputUSB 2.0
OutputCoaxial SPDIF
OutputHDMI
DAC ChipES9038Q2M
Max sampling rate768kHz
Components / ChipES9028 Q2M
StructureAluminium
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
Simply wonderful!!!
Purchased one couple of months ago.
As was originally suggested, loaded Rune Audio onto micro SD card, booted the unit, and it came up - with the screen upside down. At first I thought some one messed up and mounted the screen upside down. Turns out it was a software issue, common to many players.
I contacted Audiophonics, and after few email discussions, loaded the latest Volumio player. Everything was great - except I had no sound. After numerous email exchanges, I had Audiophonics email me assembly instructions.
I took the player completely apart, and reassembled it again. In the process I discovered that one of the GPIO pins was bent and had no contact with DAC connector - most probably the reason for sound issues.
Once again I started the unit, this time using PiCore Player and Logitech Music Server. I connected the streamer to the Emotiva USP-1 preamp, mated to Emotiva UPA-200 stereo amp and Magnepan MG 3.7 speakers and HSU Research ULS-15 Subwoofer.
Few hi-res recordings from Primophonics instantly convinced me that this player was well worth all the aggravation:
the sound was simply wonderful.
I can't wait to convert some of my organ music LPs to HiRes WAV or FLAC or maybe DSD files and play them on my RaspTouch!!! It will be glorious!
This review has been posted for RASPTOUCH I-SABRE ES9038Q2M Streamer with Touchscreen and Volume Control
