The BlueSound Node 2 is a high-definition multi-room network player that will allow you to enjoy your music without limits throughout your home.
KEY POINTS:
By buying this product you get 54 loyalty points
This product has been replaced by the new version, the BLUESOUND NODE 3.
Network reader 24bit 192kHz streamer multiroom
The NODE 2 is a 32-bit streamer multiroom reader wireless Hifi. It allows playback of your 24 bit 192Khz HD files with an audiophile sound, with a wide digital connection and Bluetooth APTX.
NODE 2 will give you access to Spotify, Deezer as well as the main streaming services and Internet radios.
Thanks to its numerous outputs, you can connect it to a wide range of digital and analog products, the NODE 2 will instantly give a second life to your equipment, even to the most vintage ones.
The Streamer Node 2 with its 32 bit Ti 5122 DAC seamlessly decodes HD files (lossless) at high sampling frequency (192KHZ). The very high computing power of the ARM Cortex 9 1 GHz multi-core processor brings a level of reactive user comfort without slowing down for the control and the diffusion of the music in streaming in all your rooms.
The NODE 2, like all Bluesound drives, is controlled from your smartphone or tablet with a free IOS or Android application.
The control interface gathers all your sources, on Cloud, on your computer, your smartphone, a NAS or almost all other sources via the inputsanalog and digital. Streamer from Wi-Fi or from Bluetooth, or connect it to your Ethernet LAN.
Whatever the source, Bluesound will be your companion High fidelity high resolution available until the resolution Studio Master 24/192.
Video test in English
You can browse your music collections from the Bluesound app on your smartphone, tablet or computer. The free Bluesound app is available under iOS and Android.
Processor | ARM Cortex TM - A9 1GHz |
Supported file formats | MP3, AAC, WMA, OGG, WMA-L, FLAC, ALAC, WAV, AIFF |
Native sampling rate | 32 - 192kHz |
bit | 16 - 24 |
Compatible operating systems | Windows Vista 7, 8, Apple Macintosh OS X 7-10 |
DAC | 32bit 192kHz |
Signal to noise ratio | -110dBa |
THD + N | 0.005% |
Orders | LED Tactiles |
Consumption | 6W |
Food | Universal AC power cord with two pins (100-240 AC) |
Connectivity / Connectivity | |
Ethernet | RJ45 GigE |
WIRELESS | 802.11 b / g / n |
Bluetooth | 4.0 aptX |
IR Optics | In front + IR remote input (3.5mm jack) |
<inputs/ Td> | 1x USB-A / 1x USB-B (for product support) |
Exits | RCA Stereo / Coaxial / Optical Toslink / Headphone Jack 3.5mm / Subwoofer RCA / Trigger 12V |
Miscellaneous | |
Dimensions | 220 x 46 x 146mm |
Weight | 1.12kg |
Color | Black |
Included Accessories | Mains cable 120V AC / Mains cable 230V AC / Ethernet cable / RCA cable Stereo to RCA / Cable 3.5mm Stereo mini to RCA / Mini Toslink optical adapter to 3.5mm / Warranty certificate / Installation guide |
