RaspTouch LTE I-Sabre - Streamer touch Raspberry Pi & DAC ES9023
RASPTOUCH LTE Open Source Player ES9023 LTE DAC / Raspberry Pi 3
2.3 / 5
Reference : 11960
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
AUDIOPHONICS RASPTOUCH LTE ES9023
The Audiophonics team is proud to present its new version of RaspTouch, the RaspTouch LTE. Based on a Raspberry Pi 3 and one DAC I-Sabre ES9023, it offers an out-of-pair compatibility with many platforms, allowing you to enjoy your entire library. In addition, its design has been revised to offer you a space-saving and flexible solution.
COMPLETE COMPATIBILITY
Comes with piCorePlayer pre-installed, this operating system allows you to enjoy just the whole of your audio library. So, whether your music is stored physically on a hard drive connected to your Raspberry Pi or on a server, you can access it without any limitation while enjoying your I-Sabre ES9023 DAC.
More than that, it works with Squeezelite and Logitech Media Server to turn your RaspTouch LTE into a true network player ,allowing you to remotely control your system. Even better, you can download and use applications like iPeng or Squeezer in order to control your player with your smartphone, directly from your sofa.
Finally, to ensure more compatibility, your device is compatible UPnP, DLNA and Airplay, allowing you to simply stream your content to your turntable.
MULTIROOM WITHOUT LIMIT
Want to enjoy your music throughout your home? The RaspTouch LTE takes care of it by offering an efficient multiroom system, allowing you to stream your files on any deck connected to your network and control them.
FREE TO CHOOSE YOUR OS
Because for us you must be able to adapt your system to your needs, we made the choice of the " Open Source. Thus, if piCorePlayer does not suit you, you are free to choose the solution that will be most effective for your uses. Raspbian, Max2Play or Kodi work perfectly with the RaspTouch LTE for example.
ACCESSIBLE HIGH FIDELITY
Based on a DAC I-Sabre ES9023capable of converting sampling rates up to 24bit / 192kHz and equipped with Ultra-low noise regulators and Low ESR filter capacitors, the RaspTouch LTE is definitely a high-end audio / video deck.
GREAT ERGONOMICS
Raspberry Pi 3, DAC I-Sabre ESS 9023 and 7 "Raspberry official touch screen allows you to tilt or fix your deck as you wish, in order to adapt to your use and your environment without any restriction.
TECHNICAL CHARACTERISTICS
Inputs
x4USB-A
x1Ethernet RJ45
x1Micro USB-B (Power Supply)
x1Slot Micro-SD
Outputs
1xRCA Stéréo
I-SABRE ES9023
Sample rate24bit 192kHz
Régultateurs Ultra Low NoiseOui
Low ESR Filter CapacitorsOui
RASPBERRY PI 3
ChipsetBroadcom BCM2837 1.2Ghz
CoreARM Cortex A53 64bit 4 coeurs
LANWireless
Bluetooth4.1
GPUDualCore
MemoryLPDDR2 1Go
Screen & Stand
Screen7" Capacitive touch 10 fingers
Resolution800 x 400 px
SupportSmartiPi Tiltable
Dimensions & Weight
Weight548g
Dimensions22L x 9.7 x 13.8H
Contenu du colis
- Streamer Touch control Rasptouch LTE I-Sabrex1
- Wall adapter 100-240V ro Micro-USB 5V 3A.x1
InputMicro SD
InputRJ45
DAC / ADC ChipES9023
Max sampling rate192kHz
3 reviews
PSU damaged
Just arrived It don't work. The PSU is damaged. I'm still waiting for replacement
This review has been posted for RaspTouch LTE I-Sabre - Streamer touch Raspberry Pi & DAC ES9023
Pas fini
Vendu comme produit fini, il n'y aucun manuel ni notice d'utilisation pourtant obligatoire selon le Code de la Consommation et bien utile pour un néophyte du raspberry pi.
Picore est peut être très bien si vous avez une box, mais ça ne fonctionne pas sinon, autre point qui devrait être mentionné.
Une fois passé ces problèmes, le produit est de bonne qualité, mais autant l'acheter par bouts et le monter soi même ...
Bonjour,
Un support complet et disponible sur le forum (sous forme de nombreux tutoriels) et nous sommes accessibles par email pour répondre à toutes questions.
Picore est une solution réseau et nécessite de fait une IP pour fonctionner.
magnifique
produit tres agreable et une tres belle ecoute
facile d utilisation une fois qu on la manipule 10 minutes
et merci au service technique qui repond tres vite aux questions
