DAYTON AUDIO DSA270-PR Passive Radiator 21.9Hz Ø25cm
DAYTON AUDIO DSA270-Fri
A passive radiator with aluminum membrane of good quality, designed to fit most of 25cm speaker modernization projects or repair. It has a 11mm excursion, allowing to emphasize the low end without distorting the dynamics of sound. It may therefore be integrated easily into ambitious and powerful speaker projects.
Reference : 13295
61,90 €tax incl.
51,58 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
DSA270 PR-10 "
Passive Radiator Aluminum ⌀25cm
DSA270-PR10
Radiator speaker passive
Its design as much as its specifications make it a very suitable radiator with the DESIGNER series in Dayton Audio. This does however not stop the radiator to offer excellent performance with other models.
To facilitate integration of the radiator and quickly achieve the best sound, the DSA207-PR comes with M5 screws, which will add weight to the radiator. This configuration lowers the resonant frequency in order to promote the natural balance of bass.
Adjusting mass resonance frequency passive radiator
Typepassive radiator
Nominal diameter25cm
Resonant Frequency (Fs)21.9 HzFs
Mechanical Q (Qms)5.26Qms
total moving mass air + Load88.4gMms
Compliance of the suspension0.6 mm / NCms
emitting surface of the membrane353 cm²sd
Volume displaced air388.3 cm³MD
compliance equivalent volume of air105.8 litersyou
maximum excursion11 mmXmax
mechanical loss2.3 kg / sRms
Membrane / diaphragmaluminum Cone
borderRubber
bowl materialSteel
overall external diameter270 mm
overall depth72.9 mm
drilling diameter227.08 mm
Number of mounting holes5
belt diameter205.99 mm
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)250.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)11.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
A passive radiator with aluminum membrane of good quality, designed to fit most of 25cm speaker modernization projects or repair. It has a 11mm...
