DAYTON AUDIO ND105-PR Passive Radiator 51.5Hz Ø10cm
DAYTON AUDIO ND105-PR Passive Radiator 51.5 Hz Ø 10 cm
A compact passive radiator 10 cm in diameter with aluminum membrane. A solid construction adapted with a frequency response of 51.5 Hz, ideal to emphasize the low frequencies of your medium and compact speakers.
Reference : 12698
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 16-04-2024.
Shipping from France
Billing in France
Technical support in France
Passive Radiator 10 pc PR-ND105 Dayton Audio
For compact speakers with deep bass
ND105 Passive Radiator Dayton Audio
mass passive radiator dayton
A simple way to fine tune the bass response frequency of a speaker
A compact passive radiator 10 cm in diameter with aluminum membrane. Solid construction adapted with a frequency response of 51.5 Hz, ideal to emphasize the bass frequencies of your midsize and compact speakers.
Its high excursion 6 mm (12mm crest to crest) gives it good performance despite reduced membrane surface. This allows him to get out deep bass without distorting the dynamics of sound. Whether deepen the bass in a system with several speakers or build a powerful portable system, the so-ND105 PR is an appropriate choice to give a serious blow to boost your building projects / improvement speaker
This passive radiator is part of the ND series Dayton Audio. It inherits the elegant and modern style and quality of manufacture of the range.
Includes an additional mass
ND105 mass-PR
To facilitate assembly and easy access to the best sounds, the PR-ND105 is supplied with an additional weight of 21.8 grams with its attachment screws. A handy tool to easily get a nice balance in low frequencies without having to play on the arrangement of speakers or the dimensions of the case.
This option is useful for accurate sound speakers on limited in size.
TypePassive radiator
SeriesND Dayton Audio
Diameter10 cm / 4 inches
Resonance Frequency51.5 Hz
Coefficient of mechanical quality (Qms)5.93
additional mass includedYes
additional mass Weight21.8 g
Mass diaphragm (air included)13.9 g
Compliance mechanical suspension0.68 mm / N
membrane area51.5 cm²
linear excursion max6 mm
mechanical loss (RMS)0.76kg / s
ConeAluminum
SideRubber
StructureSteel
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)100.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
A compact passive radiator 10 cm in diameter with aluminum membrane. A solid construction adapted with a frequency response of 51.5 Hz, ideal to...
