Q ACOUSTICS 3060S Active Subwoofer Class D 150W 35-250Hz White
The 3060S active subwoofer from Q Acoustics features a 200mm driver and an integrated amplifier capable of delivering 150W of power. If it follows the aesthetics of the Q3000i series, the Q3060s will work with any home cinema system to provide true bass depth.
By buying this product you get 39 loyalty points
Reference : 14338
399,00 €tax incl.
332,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Q Acoustics 3060S
Q Acoustics 3060S Caisson de grave actif Class D 150W 35-250Hz
Controls and connections are hidden under a magnetic hatch. The input connector is angled so that the cable, once plugged in, does not protrude unsightly from the unit.
The crossover as well as the volume level are adjustable from the outer panel. The crossover filter can be easily adjusted from 35Hz to 250Hz.
The enclosure is built in infinite baffle. This type of enclosure is ideal for high-performance woofers.
The subwoofer can be installed on a piece of furniture thanks to the four spikes supplied. It can also be placed on the floor on a soft surface (rubber feet).
Product typeActive subwoofer
Enclosure typeInfinite baffle
Frequency response (+3dB, -6dB)35Hz - 250Hz
Amplification power150W
Crossover frequency35Hz-250Hz (variable)
Amplification classClass D
Dimensions480 x 300 x 150mm
Weight8.5kg
ColorWhite
Package1x Q Acoustics 3060s
4x Spikes
1x Power cable
1x User manual
ColorWhite
Impedance (Ω)NC
Lowest frequency (Hz)35
Highest frequency (Hz)250
Power (W)150.0
Number of loudspeakers1
Speaker typeActive
The 3060S active subwoofer from Q Acoustics features a 200mm driver and an integrated amplifier capable of delivering 150W of power. If it follows...
