ELFIDELITY AXF-100 PRO III Internal USB Power Filter for PC
Elfidelity AXF-100 internal USB Power Filter for PC
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end connectivity, it will clean the USB port of the noise generated by the switch mode power supply.
Reference : 9056
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Elfidelity AXF-100 PRO III
Elfidelity AXF-100 PRO III Filtre Alimentation USB Interne pour PC
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end connectivity, it will clean the USB port of the noise generated by the switch mode power supply while allowing you to inject if you wish "clean" 5V from an external source (Battery, Linear power supply etc...). This product with advanced power management is capable of automatically switching over if, for example, the external power supply no longer supplies the module correctly.
Requires an internal USB connection on a free motherboard.
Product typeInternal USB Power Filter for PC
Max current5A
Max power25W
Automatic power supply switching speed< 5ms
Ripple factor< 1Hz
Japanese capacitors-
Shielded inductorsTDK
RelayTamakisawa (Japan)
InputJack DC 3.4 / 1.4mm
USB Connector1x USB-A 3.0
State LED indicator-
PCB Dimensions90 x 60mm
Weight130g
Package1x Internal USB 3.0 19 pins 10cm cable
InputPCI Express
InputJack DC 3.4/1.4mm
OutputNC
Output voltage (V)5.0
Output current (A)5.0
Input voltage (V)N/A
Power SupplyPower supply filter
26 reviews
Great product
I have a dedicated music pc with all Elfidelity filters(ram, fan, hdd/ssd, pcie and usb) and sounds fabulous. The USB card filter is on par with one from another brand that cost 8 times more (blind A-B test with both and no difference in sq). Highly recommend.
This review has been posted for ELFIDELITY AXF-100 PRO III Internal USB Power Filter for PC
Recommended!
For the money this is an excellent product. Simple to install and recogized by windows on reboot.For best results I would recommend complementing the card with an external linear 5V power supply. The Allo - 5V Power Supply for similar money works fine.
Very good
I purchased this based on previous reviews. And I was not wrong, is very good in terms of sound. In package is everything you need, cables and I didn't expect a charger but is there. Even if is a chinese socket with a little skill I adapted it for european socket. A solid product delivers a good signal for my Dac.
subtle improvements
This is a must have for anybody using their PC as an audio source. The sound coming directly from the motherboard sounds more compressed, while the elfidelity sounds a bit more holographic. It is subtle but noticeable. Highly recommended. The latest version of this card uses nichicon & elna electrolytic caps instead of 4 solid caps, to further improve the power quality. Thanks audiophonics for offering this product!
amélioration significative du son
je veux juste écouter, écouter et écouter encore
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end...
