Snap-fit XS10 plug 3 pin Gold plated 250V 3A Ø13mm
Snap-fit XS10 plug 3 pin Gold plated 250V 3A Ø 5mm
Reference : 10110
2,19 €tax incl.
1,83 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
These Aviation type connectors allow you to create cables with particularly strong and resistant connections.
They are suitable for all types of mounts accepting any cable with a diameter of 4mm.
NOTWe offer these connectors in versions 2, 3, 4 and 5 poles.
Characteristics :
  • Material: Stainless Steel
  • 3 poles
  • Gold plated contacts
  • Lockable by snap-fastening
  • Connector in 3 parts (screwing / snap-fastening)
  • High performance insulation
  • Welding
  • Operating Temperature Range: -55 ° C to 85 ° C
  • Max. : 93% at 40 ° C
  • Vibration frequency: 0 to 500Hz
  • Acceptable Cable Diameter: 4mm
  • Total Outside Diameter: 13mm
  • Dimensions: 44x13.5mm
  • Weight: 20g
Max cable diameter (mm)5.0
Mounting typeTo weld
ConnecticMale & Female
Contacts number3
ConnectorXS*
Connecteur aviation 3 pôles
Très bien pour réaliser un câble 'signal
Les prises sont toutes petites et les pins assez rapprochés trop juste à mon avis pour un câble secteur (noté 250v 3a)
Le câble suivant passe bien ;
NEOTECH SOCT-24 Fil de câblage Cuivre UP-OCC PTFE 0.2mm²
Aucun problème d'isolement et contact franc
Enfin le diamètre de perçage est de 10mm
This review has been posted for Snap-fit XS10 plug 3 pin Gold plated 250V 3A Ø13mm
