PERFECT SOUND GOLD Vibration Absorbers 45mm (Set x8)
PERFECT SOUND GOLD Absorbeurs de Vibrations 45mm (Set x8)
3192
55,90 €tax incl.
46,58 € tax excl.
Available
Shipping date: 24-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Perfect Sound absorbers 45mm (set x8)
These isolators (or absorbers) are designed to absorb the vibrations that could be transmitted to your Hifi and video or other devices ...
They protect the devices from vibrations that degrade the sound or video quality.
Each absorber has a 6mm diameter hole, so you can fix it.
  • Diameter: 45mm
  • Height: 15mm
  • Weight max. : 30kg
On these 45mm absorbers it is possible to add counterpointsPerfect Sound.
The absorber then becomes a supportand allows you to
to rest there spikes.
It is also possible to add decoupling points Perfect sound Black GL0460
The absorber then turns into a screw-on tip holder for your speakers or other HIFI devices,
and allows you to make them rest on counterweights
Diameter45mm
MaterialAcrylique
ColorOr
Colissimo - TNT - SoColissimo
Parfait
Il sont pile poil à la dimension des pieds des blocs mono que j'ai.
Un mieux sur le rendu. Tout est plus stable et la scène gagne en largueur et profondeur.
Livraison rapide
This review has been posted for PERFECT SOUND GOLD Vibration Absorbers 45mm (Set x8)
