VIBRAPOD ISOLATORS MODEL3 Insulator / Vibration Absorbers (Set x4)
VIBRAPOD ISOLATORS MODEL3 Isolateur/Absorbeur Vibrations (Set x4)
4.7 / 5
Reference : 2653
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
Absorbers Vibrapod x4
Vibrapod isolators (or absorbers) are designed to absorb vibrations that could be transmitted to your Hifi and video or other devices.
They protect the devices from vibrations that degrade the sound or video quality.
Because an absorber suitable for a 5kg CD player will not work for a 40kg amplifier, Vibrapod has designed 5 models to achieve optimum performance regardless of the weight of the device.
It is surely the absorbers which present the best efficiency / price ratio.
Your ears will certainly thank you ...
There are 5 models of Vibrapods depending on the weight of your components:
Model of VibrapodRecommended weight
(kg per Vibrapod)
Weight
(kg per Vibrapod)
Minimum weight of the device
for 4x Vibrapods
Model # 11.10.90 - 1.363.6 - 5.4
Model # 22.71.81 - 3.627.2 - 14.4
Model # 34.53.62 - 5.4414.4 - 21.7
Model # 47.26.35 - 8.1625.4 - 32.6
Model # 511.39.9 - 12.739.8 - 50.8
Dimensions:1.5cm high x 6.2cm in diameter.
For appliances with feet larger than 4.2cm, they can be placed directly on the dome of the Vibrapod
For appliances with feet with a diameter between 1.9 and 4cm, place them on the central island, Vibrapod upside down (photo2)
For appliances on points, add a tailstock with a minimum diameter of 1.9cm.
componentand feet
In some cases, when the bottom of the appliance is irregular,e the original feet are too small or the appliance is heated, it is advisable to use a "sandwich" mounting
You should then place your device on a shelf, which itself will rest on Vibrapod.
Remember to include the weight of the shelf when choosing the Vibrapods model.
Because of their vinyl design, it is possible that the Vibrapods leave some traces on the smooth surfaces.
Diameter (mm)62.0
MaterialRubber
Height15.0
3 reviews
Excellent produit
Bonne dimension et bon rapport qualité /prix. Prix attractif.
This review has been posted for VIBRAPOD ISOLATORS MODEL3 Insulator / Vibration Absorbers (Set x4)
Bluffant
Pour le petit budget dont je disposais, j'ai commandé le set de vibrapod sans grande conviction au départ.
Lorsque je les ai placés sous mon conditionneur de réseau, j'ai pris la précaution de les essayer sur les deux faces pour déterminer celle qui convenait le mieux (dans mon cas la surface la plus large en contact avec les pieds de l'appareil) et là, dans le rendu de l'image sonore, la sensation était que "tout prenait sa juste place".
Seul bémol, la notice non traduite en français et les spécifications d'usage en mesures anglo-saxonnes.
Très bon produit
C'est toujours assez étonnant lorsque l'on ajoute des absorbeurs à des HP. Ces vibrapod ne font pas exception. Les basses fréquences sont par magie (pas tant que cela en fait) bien moins envahissantes. L'évolution est très significative. Bien fini, bien emballé. Avec en prime les conseils d'Audiophonics.
