DAC ES9318C Male Lightning MFI to Female Jack 3.5mm Hi-Res 32bit 384kHz DSD256
This adapter integrates a male Lightning MFI connector and a female 3.5mm jack. It also embeds an ES9318C DAC allowing it to support high sampling rates up to PCM 32bit 384kHz, DSD256 and DoP128. This chip also ensures a precise and detailed sound reproduction, with a very low noise level. The cable itself benefits from a beautiful design, composed of copper and silver conductors braided together and insulated by a transparent sheath.
Reference : 16303
52,90 €tax incl.
44,08 € tax excl.
Last items in stock !
Shipping date: 26-05-2026.
Lightning / Jack 3.5mm DAC Adapter
Adaptateur DAC ES9318C Lightning MFI Mâle vers Jack 3.5mm Femelle Hi-Res 32bit 384kHz DSD256
This adapter integrates a male Lightning MFI connector and a female 3.5mm jack. It also embeds an ES9318C DAC allowing it to support high sampling rates up to PCM 32bit 384kHz, DSD256 and DoP128. This chip also ensures a precise and detailed sound reproduction, with a very low noise level. The cable itself benefits from a beautiful design, composed of copper and silver conductors braided together and insulated by a transparent sheath. The contacts of the connectors are gold plated.
Product typeLightning / Jack 3.5mm DAC Adapter
Connectors1x Male Lightning MFI
1x Female Jack 3.5mm
LengthWith connectors : 12.5cm
Without connectors : 5.5cm
DAC ChipESS ES9318C
Conductors materialCopper
Silver
Supported samplng ratesPCM up to 32bit 384kHz
DSD up to DSD256
DSD DoP up to DSD128
SNR120dB
Dynamic range120dB
THD+N< 0.000496% @32ohm
InputLightning
OutputJack 3.5mm
DAC / ADC ChipES9318
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Utilité ?
Bonjour , est ce qu'une âme charitable peut m'expliquer l'utilité de DAC ?
Si je branche mon iphone avec ce dac et que j'écoute Apple Music et des morceaux codés en audio Lossless HQ 24 bits 192 khz , qu'est ce que cela change par rapport à un câble jack classique branché sur mon casque ?
This review has been posted for DAC ES9318C Male Lightning MFI to Female Jack 3.5mm Hi-Res 32bit 384kHz DSD256
This adapter integrates a male Lightning MFI connector and a female 3.5mm jack. It also embeds an ES9318C DAC allowing it to support high sampling...
