FIIO Q3 Balanced DAC Headphone Amplifier THX AAA-28 AK4462 XMOS XUF208 32bit 768kHz DSD512
FiiO's Q3 is a high-performance, portable balanced headphone amplifier and DAC combo. Featuring a meticulous design using high-end components, it offers excellent performance for high-flying sound reproduction.
Reference : 14910
160,00 €tax incl.
133,33 € tax excl.
FiiO Q3
Balanced DAC Headphone Amplifier THX AAA AK4462 XMOS XUF208 32bit 768kHz DSD512
FiiO Q3 DAC Amplificateur Casque Symétrique THX AAA AK4462 XMOS XUF208 32bit 768kHz DSD512
THX AAA-28 Amplifier
The amplifier stage of the Q3 uses a THX AAA-28 chip with special technology to achieve a very low level of distortion for high power, while maintaining a neutral and pure sound.
AKM AK4462 Chip
The digital/analog conversion stage is entrusted to a DAC AKM AK4462 chip, integrating the proprietary Velvet Sound technology. This chip supports high sample rates up to 32bit 768kHz PCM and up to native DSD512. You will be able to enjoy your high-resolution files and the finest details of your favorite songs.
USB XMOS Interface
An XMOS XUF208 chip provides the Q3 with high-quality USB audio signal reception, while also supporting high-resolution file support, so you can take full advantage of the Q3's DAC performance.
Design
In the continuity of the other models already proposed by FiiO, the Q3 takes up the design, sober and elegant thanks to soft curves. The case is made of Aluminum and is particularly robust.
Connectors & LED Indicator
The Q3 is equipped with a complete set of connectors, with the output of the 3.5mm asymmetrical jack and the 2.5mm / 4.4mm symmetrical jack. It will therefore allow you to connect all types of helmets.
The RGB LED indicator on the volume knob changes color to quickly identify the sample rate of the file being played back.
  • ≤ 48kHz : Blue
  • 48kHz : Yellow
  • DSD : Green
Output priority: Jack 4.4mm balanced = Jack 2.5mm balanced > Jack 3.5mm unbalanced. If the balanced 4.4mm jack and the unbalanced 2.5mm jack are connected simultaneously, no output will be available.
Versatility
The Q3 adapts to all situations and all types of listening. For example, the Bass Boost function can be turned on or off with a switch. For this feature, a hardware circuit increases the gain by 6dB in the low frequencies, without affecting the mid and high frequencies.
In addition, for more convenient use, a multi-function button allows you to quickly select a gain level or filter.
Precise volume control
Using an analog volume control, the Q3 provides precise volume level adjustment. An ADC reconstruction curve is also used to overcome the typical problems associated with analog controls.
High degree of autonomy
Taking advantage of a 1800mAh battery, the FiiO Q3 ensures an important autonomy of at least 10 hours, or more in USB decoding mode.
Shielding
The Q3 with its Aluminum housing and Copper-Nickel shielding effectively repels RFI interference that could degrade signal quality.
Product typeBalanced DAC & Headphone amplifier
Inputs1x USB-C
1x Jack 3.5mm
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 2.5mm
1x Balanced Jack 4.4mm
Channel balance≤ 0.2dB
Recommended headphone impedance16~100Ω (PO)
16~300Ω (Symétrique)
Battery capacity1800mAh
Charging time≤ 2h
AutonomyUSB Input : PO : 10h / Balanced : 8.5h
AUX Input : Balanced  : 19h
Supported sampling ratesPCM up to 32bit 768kHz
DSD Native up to DSD512
DAC ChipAKM AK4462
Amplifier chipTHX-AAA28
USB InterfaceXMOS XUF208
LPFAOP OPA1662
Single-ended Jack 3.5mm Headphone Output
Power150mW @ 16Ω, THD+N < 1%, USB Input
160mW @ 32Ω, THD+N < 1%, USB Input
19mW @ 300Ω, THD+N < 1%, USB Input
Output impedance1.2Ω (32Ω load)
Channel separation≥ 75dB (1kHz, 32Ω load)
≥ 105dB (1kHz, no load)
Frequency response20Hz - 20kHz (curve amplitude variation : 0.4dB)
20Hz - 65kHz (curve amplitude variation : -3dB)
Amplitude2.26V (32Ω / THD+N < 1%)
2.38V (no load)
Noise floor< 5.5µV (A-Weighted)
SNR≥ 114dB (32Ω, A-Weighted)
THD+N< 0.0012%
Balanced Jack 2.5mm / Jack 4.4mm Headphone output
Power180mW @ 16Ω, THD+N < 1%, USB Input
300mW @ 32Ω, THD+N < 1%, USB Input
35mW @ 300Ω, THD+N < 1%, USB Input
190mW @ 16Ω, THD+N < 1%, AUX Input
325mW @ 32Ω, THD+N < 1%, AUX Input
100mW @ 300Ω, THD+N < 1%, AUX Input
Frequency response20Hz - 20kHz (curve amplitude variation : 0.4dB, USB Input)
20Hz - 65kHz (curve amplitude variation : -3dB, USB Input)
20Hz - 90kHz (curve amplitude variation : 0.4dB, AUX Input)
Amplitude3.1V (32Ω / THD+N < 1% / USB Input)
3.38V (No load, USB input)
3.2V (32Ω / THD+N < 1% / AUX Input)
5.6V (No load, AUX Input)
Noise floor< 8µV (A-Weighted, USB Input)
< 5.5µV (A-Weighted, AUX Input)
SNR≥ 113dB (32Ω, A-Weighted, USB Input)
≥ 115dB (32Ω, A-Weighted, AUX Input)
THD+N< 0.0015% (USB Input)
< 0.0012% (AUX Input)
Output impedance3Ω (32Ω load)
Channel separation≥ 99dB (1kHz, 32Ω load)
≥ 103dB (1kHz, no load)
Dimensions105 x 59 x 12.5mm
Weight110g
Housing materialCNC machined Aluminum
InputJack 3.5mm
OutputJack 3.5mm
OutputJack 4.4mm
OutputJack 2.5mm
3 reviews
parfait!
reçu rapidement, merci encore a vous !
après avoir eu le Q1, je ne regrette pas le Q3,il apporte plus de détail définition, précision, c'est chirurgicale ! couplé a mon baladeur Fiio M7 le couple fait des merveilles !
This review has been posted for FIIO Q3 Balanced DAC Headphone Amplifier THX AAA-28 AK4462 XMOS XUF208 32bit 768kHz DSD512
Excellent rapport qualité prix
A la suite de l'achat d'un beau casque, je me suis laissé tenté par cet at ampli sac qui fait remarquablement bien le travail.
La construction est sérieuse, la molette de volume précise.
Je l'utilise avec un OnePlus 5t pour steamer Qobuz et ça fonctionne très bien. J'ai gagné en précision, rendu et puissance. J'ai cependant dû faire l'acquisition d'une application (UAPP) afin que soient reconnus les formats hi res.
Les câbles USB auraient gagné à être un peu plus long, mais rien de rédhibitoire.
Bref, bon rapport qualité/prix.
Excellent
Je cherchais un dac pour pouvoir compléter mon iPhone et je dois dire que je ne regrette absolument pas
FiiO's Q3 is a high-performance, portable balanced headphone amplifier and DAC combo. Featuring a meticulous design using high-end components,...
