IBASSO DC01 Balanced DAC Adapter Headphone amplifier USB-C Hi-Res AK4493 32bit 384kHz DSD256
Audio-GD
The iBasso DC01 is a symmetrical DAC adapter with an AK4493 digital-to-analog conversion chip, supporting high sampling rates. It is particularly suitable for use on smartphones since it has an input on a USB-C connector, but can also be used with a computer as a sound card.
4.7 / 5
Reference : 13919
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
iBasso DC01
Balanced DAC Adapter USB-C Hi-Res AK4493 32bit 384kHz DSD256
iBasso DC01 Adaptateur DAC Symétrique USB-C Hi-Res AK4493 32bit 384kHz DSD256iBasso DC01 Adaptateur DAC Symétrique USB-C Hi-Res AK4493 32bit 384kHz DSD256
AKM AK4493EQ DAC
The DC01 is equipped with an AK4493 digital-to-analog conversion chip normally used in high-end sedentary DACs and integrating AKM Velvet Sound™ technology. The signal-to-noise ratio of this chip has been significantly improved compared to the previous model, the AK4490, which allows the DC01 to support high sampling rates up to 32bit 384kHz in PCM and up to native DSD256, while providing a THD+N of less than 0.001%. A design that will allow you to enjoy your music to the fullest, whether for use at home or on the move.
Balanced headphone amplifier
iBasso imports the concept of balanced amplification, normally reserved for high-end audio equipment, into this portable DAC adapter. The DC01 uses a fully balanced circuit with ultra-low distortion dual LDO to create a balanced amplifier, providing high output power while improving dynamics and overall reproduction quality.
High-end cable
In order to ensure optimal signal conductivity for excellent audio reproduction but also very good durability, iBasso carried out numerous tests before selecting this cable made of 8 braided wires.
From smartphone to computer : USB UAC2.0 Soundcard
The DC01 is equipped with a USB-C connector and uses the USB UAC2.0 reception standard. It is compatible with the vast majority of Android smartphones and tablets on the market. It is also able to connect to a computer under Mac OS or Windows using the supplied USB-C to USB-A high quality adapter. This allows it to work exactly like a sound card, and in an extremely simple way since the system is Plug & Play.
For computers running Windows XP, Windows 7 or Windows 8, download and install the driver available in the "Download" tab of this page.
Volume control app
Windows 10 and Android 5.0 (or higher) support the UAC2.0 protocol by default. However, for compatibility reasons, Android smartphone manufacturers still use the SRC protocol on the audio output. When the DC01 is connected, the volume is set to the maximum by default and the device's software algorithm is used to reduce the volume. While this method does reduce the volume, it does not reduce the noise threshold. Thus, iBasso has developed a volume control application using the UAC2.0 protocol to allow 64 steps of hardware volume control while reducing the noise threshold and offering much better audio performance.
The DC01 has compatibility problems with Samsung S9 and S10 smartphones but works perfectly with other models on the market.
Product typeDAC Adapter
DAC ChipAKM AK4493EQ
Output power113mW @ 32Ω
Output voltage1.9V @ 32Ω
Frequency response20Hz - 40kHz +/-0.5dB
DAC USB Mode
InputUSB-C
OutputBalanced Jack 2.5mm
THD+N< 0.001% @ 32Ω, 1.2Vrms
Supported sampling ratesPCM : Up to 32bit 384kHz
DSD Natif Up to DSD256
Length120mm
Weight11g
ColorSilver
OutputJack 2.5mm
ColorSilver
7 reviews
Petit mais costaud !
Un petit dac nomade/ ampli casque digne d’intérêt. Eu égard à son prix raisonnable, il constitue un très bon choix. Initialement, bien que sa sortie soit symétrique, je l’avais utilisé de façon asymétrique en lui adjoignant un petit adaptateur jack. Cela fonctionne, même pas trop mal, mais ce n’est pas l’idéal : mieux vaut s’orienter dans ce cas vers le DC03 (que je possède aussi, et qui procure un très bon son). Mais lorsque je me suis décidé à acheter un câble symétrique, j’ai enfin pu utiliser le DC01 de la bonne manière, et je dois avouer que le résultat est stupéfiant. Couplé par exemple avec le Meze 99 Classics, il fait sonner ce casque de façon optimale (pour un résultat meilleur qu’avec le câble symétrique , car l’effet de basses un peu trop prononcées s’estompe). Les seuls reproches que je lui ferais concernent la longueur de son câble tressé, qui lui donne l’air de pendouiller un peu lamentablement au bout d’un port usb, sa chaleur excessive même en usage modéré, (problème que je ne rencontre pas avec le Dc03) et sa consommation moins contenue qu’avec les dac des générations ultérieures.
This review has been posted for IBASSO DC01 Balanced DAC Adapter Headphone amplifier USB-C Hi-Res AK4493 32bit 384kHz DSD256
je le recommande...
Je possède un MacBook pro avec un casque Bose AE2
Le son est nettement amélioré avec des meilleurs basse
A acheter les yeux fermés
Miniaturisation bluffante
Qualité son au RDV, pas exceptionnel non plus ça reste un DAC Sigma Delta mais pour le prix...
Excellent rapport qualité/prix, excellentes performances
Ce petit (tout petit) DAC en a sous son petit capot. Le son est propre, précis, les basses sont puissantes mais pas baveuses.
Niveau puissance il alimente sans broncher un casque planar.
Aucun problème en PCM, il suffit de brancher et cela fonctionne.
J'étais inquiet en DSD (DoP) car ce DAC n'a pas de bouton de volume. En fait ça fonctionne impeccablement (j'ai testé avec USB Audio Player Pro sous Android et Audirvana sous macOS).
Malgré les remarques vues ci et là concernant le Samsung S9, le mien s'en accommode parfaitement.
Enfin, pour une mystérieuse raison il est bien reconnu en PCM jusque 384MHz mais "seulement" jusque DSD128 (et pas DSD256).
Très bon DAC mais...
Très bon DAC. Le son est propre, précis, sans filtrage ajouté. L'application répond très bien sur un SamsungA5. Mais pourquoi un jack 2.5? Il faut ajouter un adaptateur...Mauvais design.
Cette connectique est prévue pour un usage avec un casque ou des intras Symétriques.
L'usage d'un adaptateur est déconseillé par la marque.
Ils ont créé le DC02 pour ceux qui disposent de matériel plus classique (asymétrique).
The iBasso DC01 is a symmetrical DAC adapter with an AK4493 digital-to-analog conversion chip, supporting high sampling rates. It is particularly...
