DAYTON AUDIO XRA25 Rear channel Wireless Digital Amplifier Stereo 2x 12W / 8Ohm
DAYTON AUDIO XRA25 Amplificateur Numérique sans fil Stereo 25W
Reference : 9308
159,00 €tax incl.
132,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The XRA25 is an audio system with high performance wireless amplifier of 100m range.
The system consists of two housings. The first (transmitter) is intended to receive the audio source and the second (receiver) receives the information to transmit it to the speakers directly to which it is connected.
The exRA25 also gives you the option of connecting a Subwoofer. A channel has been provided for this purpose.
Thus, you can organize the audio configuration of your 5.1 home cinema room with great ease. Forget the wires under the carpet or fixed to the floor with adhesive ...
Features:/ Strong>
  • 2 Power Supplies
  • 2 brackets supplied
  • 2 HP cables supplied
  • Transmission 2.4GHz / 30m range
  • Manual pairing possible between transmitter and receiver in case of conflict
  • Avoids cable lengths in the room
  • Volume control via potentiometer on receiver
  • Input RCA Line (1V)
  • Input Subwoofer RCA (2V)
  • HP input on clamp terminals high level
  • HP output on wire clamp terminals
  • RCA Subwoofer Output (2V)
Specifications:
  • Frequency Response : 20kHz - 20kHz
  • Signal Noise Ratio :> 80dB
  • Rated Power: 2x 25 Watts / 4Ω
    2x 12 Watts / 8Ω
  • Dimensions: 175x99x40mm (L x W x H)
  • Weight: 1.5kg
