ELECAUDIO Dualbloc 22 Stereo Power Amplifier TA2022 1x 150W / 8 Ohm
ELECAUDIO Dualbloc 22 Amplificateur de puissance Stéréo TA2022
4.4 / 5
Reference : 7349
219,00 €tax incl.
182,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Architectured around the now famous to be knownTRIPATH TA2022, this new stereo power block is ideal for the most daring installations made up of multiple blocks.
This device develops 90 Watts per channel under 4Ω with 0.1% THD , a very satisfactory power capable of reviving an installation and which although seemingly limited, truly succeeds in surprising by its dynamics and its transparency.
This stereo power block has an input XLR balanced (mono for use in bridged mode) as well as an entry RCA Stereo switchable via a switch. (Switching the device off).
The integration of a Trigger input enables this power block to be switched on via a 12V signal sent, for example, by a preamplifier.
Its linear power supply with toroidal transformer in substitution of the conventional switching power supplies generally encountered on this type of product makes it possible to limit the harmful effects of the switchings and their harmonics on the high frequencies.
Theis made up of electrolytic capacitorssPanasonic FCand a150VA toroidal transformerwinding machine with overheating protection.
Subtle blend of finesse and firmness, this amplifier of great generosity provides joy and emotion as few others know how to do in this price range.
Warning, this amplifier may be sensitive to radio interference from FM radios and tuners./ P>
Specifications:
  • Housing 100% Aluminum
  • Input Trigger for controlling the ignition by a preamplifier
  • Class -T amplifier circuitTRIPATH TA2022
  • Capacitors Panasonic FC
  • Stereo use: Stereo line input RCA
  • Mono Bridged use: Mono line input on XLR Symmetric or RCA
  • High quality RCA Plated Gold Plated 24k
  • Outings onHP insulated and gold-plated 24k and accepting cables of large cross-section
  • HP mono output on BTL screen-printed red connectors (input on white RCA / switching under device required)
Specifications:
  • PuiOutput Channel:
    • Mono Bridge (for 8ohm and + speakers): 1 x 150W under 8Ω (0.1% THD + N)
  • Total Harmonic Distortion Rate:0.05% (1 KHz)
  • Frequency Response: 15Hz - 80kHz (-1db)
  • Signal Noise Ratio:92dB
  • Sensitivity Line Input: 2000mV
  • Yield:Up to 90%
  • Food :AC 110V-230V (± 10%) 50 / 60Hz
  • Maximum Power Consumption:150W
  • Dimensions:165 x 260 x 60 mm
  • Weight:3.7 Kg
  • Supplied mains cable
https://www.audiophonics.fr/images2/7349/7349_ELECAUDIO_DUALBLOCK22_2.jpg
https://www.audiophonics.fr/images2/7349/7349_ELECAUDIO_DUALBLOCK22_3.jpg
https://www.audiophonics.fr/images2/7349/7349_ELECAUDIO_DUALBLOCK22_4.jpg
https://www.audiophonics.fr/images2/7349/7349_ELECAUDIO_DUALBLOCK22_5.jpg
https://www.audiophonics.fr/images2/7349/7349_ELECAUDIO_DUALBLOCK22_6.jpg
[Img-10311-left-thickbox_default]
10 reviews
Un bon Bloc mono
En faite après plus d'un an, j'en possède toujours (une paire), il faut juste les comprendre et les associer avec un bon pré-ampli, apparemment le bon pré après tellement de différents essais, est le Pier audio PB-8SE hybride 4 tubes. Ils sont fait pour être utilisé mono à mon avis d'après mon expérience. Rapport/qualité/prix ils sont excellents
This review has been posted for ELECAUDIO Dualbloc 22 Stereo Power Amplifier TA2022 1x 150W / 8 Ohm
Surpris
Tres surpris par la qualité du son de ce petit ampli. Tres clair, tres détaillé, relié à un pré-amp à tube, un dac musical-fid.. et à un pc optimisé. Drive parfaitement bien des T. comête. Le son est tres live. Ecouté du jazz vocale est un plaisir. Moins rond et chaleureux d'un amp à tube quand même. En tout cas mieux que mon advance acoustic MA150 qui est déja pas mal.
 (3)
Petit, costaud et très silencieux.
Testé avec un DAC Sanskrit depuis un PC, sans préamp, sans rien, au plus court du signal numérique. Enceintes Atohm Scirocco 1.0 (6ohms) rodées.
Gros point fort N.1: pas de préampli donc le gain est maxi en permanence chez moi, et malgré cela, aucun souffle, même l'oreille collée au tweeter. Impressionant.
Point fort N.2: entre 8W et 32W de consommation, même à pleine puissance, jamais vu ça. Le bloc reste froid après une heure d'écoute à pleine puissance.
Point fort N.3: Le son est clair, complet, ultra dynamique et permet de driver mes Atohm (120W, 6ohms) sans aucun problème pour remplir ma pièce de 400 m3 :) 20/20 sur toute la ligne.
Note: le bloc est PETIT : 18x26x5cm approx.
Pas encore testé en bridge, mais j'aimerais bien.
Mise à jour de mes propos concernant ces bloc
Je voudrais revenir sur mes propos quelque peu brutaux mais fondé concernant ces bloc. Les techniciens n'ont pas été clair et transparent dès le départ ce qui m'a excédé, protégé ces produits dans une certaine limite est acceptable. Audiophonics ne peut que faire apparaître à ses clients les Spécifications communiqué par le constructeur qui gagnerait aussi à fournir un livret plus étayé avec les bloc. En lisant Audiophonics je m'aperçois après rectification que les bloc travaille en 8 Ohms mode bridgé, Je les ai acheté pour des Q Acoustics 2050i 6 Ohms, une enceinte presque médiocre, m'en suis débarrassé dans l'attente des JBL 4435 8 Ohms avec un classé audio CA400, je vais donc faire l'essai car j'aimerais les utiliser pour autre chose. Ces bloc peut-être un bon produit si Elecaudio accepte de construire 2 versions une mono et une stéréo en double mono revu et corrigé, l'alim... etc ce qui n'est pas la mer à boire.
En définitif, Non !
J'en possède 2 je les essayé avec un pré Shanling PH 300 hybride problème de sensibilité puis avec un pré Pier audio encore pas ça. En stéréo pas assez de puissance et bridgé mono au delà de la moitié de toute la puissance un son donnant l'impression d'incompatibilité ça suffoque quelque part. Je me suis posé la question pourquoi pas les faire upgrader car quelque chose à l'intérieur ne tourne pas rond certains composants ne sont pas à leur place ou de mauvaise qualité. Je les ai envoyer chez AM audiodesign/Pier audio une référence dans le monde du tube et qui vous upgrade presque tout !
voilà ce qu'il pense des dualbloc 22 ainsi que du récepteur convertisseur wifi Shanling DR2.1
copier/coller:
Bonsoir,
Résultats des tests. Les 150 W (sous 4 ohms donc 90 W 8 ohms) ne sont pas atteints l'ampli se met en sécurité et sous 4 ohms l'ampli s'écroule c'est un (2x45W sous 8 ohms limite) .
De plus la puissance subjective n'est pas au niveau des 150w annoncée et le grave est timide médium fade, un des mes amplis de 20 W parait plus puissant que l'elec audio. Conclusion il faudra investir dans un ampli classe ab classique (pas de classe d ou T) ou un ampli à tube.
Le point positif c'est qu'il n'est pas agressif il est au niveau d'un Devialet de ce côté il ne faut avoir aucun regret.
Donc pas de modifs sur cet ampli, le convertisseur wifi utilisé seul est anémique et l'équilibre porté sur le haut du spectre un peu dur, par contre avec un dac externe raccordé sur la sortie numérique c'est infiniment mieux.
Voilà pour les essais.
Cdt.
AM
Conclusion, je vends les dualbloc Twenty two d'Elecaudio et sans rancune !
Bonjour, nous avons bien pris connaissance de votre message.
Une erreur s'était glissée dans la fiche, concernant la puissance bridgée.
Nous avions inscrit sous 4ohm, alors que c'est sous 8ohm.
Cet ampli doit être utilisé en mode bridgé uniquement sur des enceintes en 8Ohm et plus, sinon la protection en courant intervient très vite, et l'on perd l'intérêt de ce mode.
En clair, l'ampli sera plus puissant en mode non bridgé sous 4ohm, qu'en bridgé à cause de la limitation en courant.
Le mode bridgé apporte un gain en puissance pour des enceintes à haute impédance > 8ohm.
Dans le Dualbloc la puce TA2022 est alimentée en 33VDC, qui est une valeur médiane entre la tension optimale de 31V pour du 4ohm, et 35V pour du 8ohm.
Selon la datasheet la puissance est de 60W pour un canal sous 35VDC, ce qui n'est pas si éloigné des 2x45W mesurés par notre confrère.
