IPAR 1023B power amplifier Class A/B LM317 2x50W / 8 Ohm
IPARD AUDIO 1023B power amplifier LM317 2x60W / 8 Ohm
The 1023B is a compact and efficient Class AB power amplifier. It uses a very careful power design and proven audio components.
By buying this product you get 28 loyalty points
Reference : 13076
289,00 €tax incl.
240,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
IPAR 1023B
Power amplifier 2 x 50W / 8 Ohm
Power amplifier Ipar 1023B
The 1023B is a compact and efficient class power AB amplifier.
It has a well-designed power-supply and uses well-known audio components to provide a clear and precise sound while reducing interferences and environmental noises associated with regular power amplifiers.
Capable of producing 50W RMS per channel, the device does not compromise on power, thus being an ideal choice for a room-sized sound-system.
Class AB amplifier IPAR 1023B
The amplification stage works with complementary power transistors NJW0281 / NJW0302, BD139 / BD140 and a Epitaxial BC560 transistor. Those components are chosen for their excellent linearity in the gain as well as their large headroom.
Furthermore, these elements are designed to withstand high voltages while maintaining a very low noise level. This allows the amplifier to develop an impressive power for its size while maintaining a clear and defined sound.
Well-designed power stage
The regulated linear power of 1023B operates a high-power ring transformer isolated with an iron cover which significantly reduces vibration and noise. It is designed to support up to 300W, a comfortable room to return a deep dynamic without causing additional distortion. The circuit is designed so that the voltage and current are completely independent.
With two consecutive 30A bridges and a set of capacitors ELNA 40,000 uF, the power stage features an excellent stability, which allows to significantly improve the signal / noise ratio (105dB).
An LM317 regulator maintains a stable voltage to a level that is ideal for complementary power transistors (NJW0281 / NJW0302), preserving the excellent linearity of the gain.
The power goes through a Omron power relay to prevent unwanted noises during power up.
regulated linear power amplifier supply
https://www.audiophonics.fr/img/cms/Images/Produits/13K/13076/radiateur.jpg
Management of thermal stresses
All critical components are mounted on the heat sink, thus providing considerable power while maintaining thermal stresses under controlled threshold.
The radiator has for this purpose fins of 36 mm for a very efficient passive cooling.
Adjustable input voltage
A switch located just above the power cable toggles between two input voltages (220/110 V) so as not to be geographically limited by electrical codes.
voltage selector input
Amplifier IPAR 1023
To go further, the 1023B amplifier ideally combines with the 1023A preamplifier model. This configuration provides a whole preamplifier / headphone amplifier / source selector / volume control / power amplifier while taking advantage of matching specifications.
Characteristics
TypePower amplifier
Power Supply100V - 220V
InputRCA stereo
Output Power2x 50 Watts (charge 8 ohms)
Frequency response10-20kHz (± 0.04 dB)
THD0.0063% (50W RMS 8 Ohms)
SNR105dB
Dimensions260 x 78 x 198 mm
Weight6,3kg
Parts included
IPAR 1023Bx1
Pièces fournies
IPAR 1023Bx1
accessories not included
Power cable (Available as accessories)
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipNJW0281
Amplifier chipBD139
Amplifier chipEpitaxial BC560
Amplifier chipNJW0302
Amplifier chipBD140
Power (W)50.0
4 reviews
dynamique et transparent
Je l'ai connecté sur un Préamplificateur Passif / Sélecteur de Source 10k KHOZMO ACOUSTIC. Transparent, relief des plans sonores, beaux timbres, aucune agressivité, cet ampli est musical. Il parait bien fabriqué et vu le poids/taille du transformateur, il explique une partie des qualités auditives de cet appareil. Bon, une fois n'est pas coutume chez Audiophonic, mais une ailette du dissipateur thermique coté entrée était fléchie (le transport sans doute), je l'ai redressé et tout est en ordre. Amplificateur à recommander !
This review has been posted for IPAR 1023B power amplifier Class A/B LM317 2x50W / 8 Ohm
tres bon ampli
dynamique fantastique ,aeré et precis
hautement recommandé
Petit mais costaud
N'hésitez pas, je confirme le post précédent, c'est un amplificateur d'une grande musicalité.
Il délivre un beau rendu sonore sur l'ensemble du spectre, détaillé et précis, avec une belle image 3D, ou chaque élément sonore est à sa place, avec de beaux timbres, et sans aucune fatigue auditive.
La dynamique est au rendez vous avec une bonne gestion de la micro et macro dynamique.
L'ensemble de la connectique respire la qualité.
Pour ma part, je l'ai associé au préamplificateur Class A AUDIOPHONICS et se n'est que du plaisir.
Merci à Audiophonics pour sa large gamme de produit qualitatif
Une véritable révélation !
Ce bloc d'amplification Ipar 1023B est exceptionnel de part sa musicalité.
C'est un fil droit. Il est neutre, dynamique et très bien timbré. Aucune agressivité, grande aération des plans sonores. De plus il chauffe peu. Il ne lui manque rien. Surtout à ce prix.
Il se marie parfaitement bien avec le préampli Little Dot mk3.
Le tube lui apporte encore plus de timbres fruités.
