Kit cable DIY Audiophonics Sector PCG3 Shielded 3x2.5mm² 2m
Kit câble DIY Audiophonics Secteur PCG3 Blindé 3x2.5mm² 2.00m
4.0 / 5
Reference : 2360
27,90 €tax incl.
23,25 € tax excl.
Instead of 39,40 €
Shipping from France
Billing in France
Technical support in France
Pack content
Kit cable DIY Audiophonics Sector PCG3 Shielded 3x2.5mm² 2.00m
Audiophonics markets its audio cables in kit so you can enjoy the quality of its equipment at a lower cost.
All necessary components are supplied to build a cable identical to the mounted version.
  • Each 2.5mm² conductor consists of 50 strands of 0.25mm copper
  • High impedance PVC insulation (> 20 Gohm x cm)
  • Electromagnetic shielding (EMI) by a tinned copper braid with low coupling resistance (250ohm / km @ 30MHz)
  • Phase reversal Schuko connector
  • Braided nylon outer sheath
  • Diameter 13mm
If you want this cable mounted, we offer a mounting package.
Please go to
the following forme
to take advantage of our offer:
https://www.audiophonics.fr/images2/5188/5188_CABLE_ASSEMBLY_5.jpg
Result once the mounted cable:
https://www.audiophonics.fr/images2/2359/2359_POWER_CABLE_KIT_PCG3_1.jpg
https://www.audiophonics.fr/images2/2359/2359_POWER_CABLE_KIT_PCG3_2.jpg
IEC connector:
https://www.audiophonics.fr/images2/7719/7719_WIRABLE_IEC_C13_GOLD_1.jpg
Length (m)2.0
Section (mm²)2.5
ConnectorSchuko
ConnectorIEC C13
2 reviews
la prise IEC 13 est un peu juste par rapport au cable et à la prise schuko. la protection de cable est inutilisable de cette prise (IEC) est inutilisable avec le cable fourni. sinon cable ok aucun autre souci .
This review has been posted for Kit cable DIY Audiophonics Sector PCG3 Shielded 3x2.5mm² 2m
Super câble
Juste un petit reproche: la partie de l'IEC13 destiné à protéger le câble qui est prévue pour un diamètre 8mm et non 11mm comme celui du câble donc impossible à rentrer. Dommage!
