Dry and precise. No Color the sound. Hard, not soft.
I recommend.
Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² 1.5m
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our workshops in France. It only includes high quality components, selected for their electrical performance and their ability to transmit a clean signal.
The Elecaudio CS-331B is a power cable that integrates materials and technologies usually reserved for products with much higher prices. Thus, each conductor consists of 7 strands, themselves composed of 10 strands of OFC Copper with a diameter of 0.25mm each, for a cross-section per conductor of 3.5mm².
These 3 conductors are individually insulated by a PVC sheath and held in place by a Cotton insert providing both flexibility and firmness to the assembly..
The cable also has double shielding. The first one uses an Aluminium strip, while the second one is a screen made of finely braided Copper. Between these two shields, an OFC Copper drain wire runs through the entire cable to ensure a linear grounding to ensure reinforced protection against radio (RFI) and electromagnetic (EMI) interference.
The unit is protected by a thick 3.5mm thick PVC protection sheath, ensuring excellent cable durability. The cable is finally covered by a Viablue braided nylon sheath with the most beautiful effect.
The Audiophonics Stealth is equipped with a Schuko Elecaudio PS-24GC connector and a IEC C15 Elecaudio PI-24GC. They have a transparent nylon body, allowing the inside of the connector to appear. All the metal parts and in particular the contact and ground parts are 24k Gold plated on a thickness of 3µ. This plating provides greater resistance to oxidation but also very good signal conductivity. In the Schuko connector, the conductors are placed in a Viablue OFC Copper protective tips and allow better contact with the connector clamping system.
Product type | Power cable |
Length | 1.5m |
Connectors | 1x Schuko (Elecaudio PS-24GC) 1x IEC C15 (Elecaudio PI-24GC) |
Connectors plating | Or 24k 3µ |
Cable conductors | 3x 3.5mm², OFC Copper |
Cable shielding | Aluminium foil Copper braid OFC Copper drain wire |
Cable conductors insulation | PVC |
Cable filling | Coton |
Cable sheath | PVC, 3.5mm |
Cable covering sheath | Extensible braided sheath, Nylon PET, Black (Viablue) |
Cable diameter | Ø16mm |
Voltage / Current | 250V / 16A |
Colors | Cable: Black Connectors : Transparent and Black |
Weight | 550g |
Length (m) | 1.5 |
Shielding | Yes |
Section (mm²) | 3.50 |
Connector | IEC C13 |
Connector | Schuko |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 4.9 / 5 18 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jyrki K.
Christian G.
Jean-Christophe R.
Cédric R.
