AUDIOPHONICS STEALTH Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² 1.5m
ELECAUDIO Silver Line MKI Power cable OCC 3x3.5mm² C13 1.5m
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our workshops in France. It only includes high quality components, selected for their electrical performance and their ability to transmit a clean signal.
4.9 / 5
Reference : 11846
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Audiophonics Stealth Câble Secteur Schuko C13 Cuivre OFC Blindé 3x3.5mm² 1.5m
Elecaudio CS-331B Cable
The Elecaudio CS-331B is a power cable that integrates materials and technologies usually reserved for products with much higher prices. Thus, each conductor consists of 7 strands, themselves composed of 10 strands of OFC Copper with a diameter of 0.25mm each, for a cross-section per conductor of 3.5mm².
These 3 conductors are individually insulated by a PVC sheath and held in place by a Cotton insert providing both flexibility and firmness to the assembly..
The cable also has double shielding. The first one uses an Aluminium strip, while the second one is a screen made of finely braided Copper. Between these two shields, an OFC Copper drain wire runs through the entire cable to ensure a linear grounding to ensure reinforced protection against radio (RFI) and electromagnetic (EMI) interference.
The unit is protected by a thick 3.5mm thick PVC protection sheath, ensuring excellent cable durability. The cable is finally covered by a Viablue braided nylon sheath with the most beautiful effect.
Elecaudio PS-24GC and PI-24GC connectors
The Audiophonics Stealth is equipped with a Schuko Elecaudio PS-24GC connector and a IEC C15 Elecaudio PI-24GC. They have a transparent nylon body, allowing the inside of the connector to appear. All the metal parts and in particular the contact and ground parts are 24k Gold plated on a thickness of 3µ. This plating provides greater resistance to oxidation but also very good signal conductivity. In the Schuko connector, the conductors are placed in a Viablue OFC Copper protective tips and allow better contact with the connector clamping system.
Product typePower cable
Length1.5m
Connectors1x Schuko (Elecaudio PS-24GC)
1x IEC C15 (Elecaudio PI-24GC)
Connectors platingOr 24k 3µ
Cable conductors3x 3.5mm², OFC Copper
Cable shieldingAluminium foil
Copper braid
Cable conductors insulationPVC
Cable fillingCoton
Cable sheathPVC, 3.5mm
Cable covering sheathExtensible braided sheath, Nylon PET, Black (Viablue)
Cable diameterØ16mm
Voltage / Current250V / 16A
ColorsCable: Black
Connectors : Transparent and Black
Weight550g
Length (m)1.5
ShieldingYes
Section (mm²)3.50
ConnectorIEC C13
ConnectorSchuko
18 reviews
Jyrki
Dry and precise. No Color the sound. Hard, not soft.
I recommend.
This review has been posted for AUDIOPHONICS STEALTH Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² 1.5m
Un câble secteur impressionnant
La taille du câble est énorme et la fabrication est vraiment de qualité. Branché sur un ampli casque Audio GD, le résultat auditif donne une belle musicalité. Du grave à l'aigu tout semble parfaitement équilibré. Pour un prix raisonnable c'est un très bel équipement.
Secteur
Câble de qualité que je raccorde à une barrette Audiphonics
Attention section importante et du coup assez rigide
Que demander de plus
Un câble de bonne qualité. Diamètre assez important mais assez souple.
Excellente base pour tout matériel de puissance, alim, ampli, intégré...
satisfait
excellent produit. livré dans les temps. bien empaqueté
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end...
