OYAIDE TUNAMI GPXe V2 Power Cable Schuko IEC C15 PC-OCC-A Copper Gold 24k Palladium Plated 1.8m
OYAIDE TUNAMI GPX-R V2 Power cable PC-OCC-A / OFC IEC C15 Plated Palladium 1,8m
This high quality Oyaide Tunami GPXe power cable is equipped with a Schuko and an IEC C15 connectors, with 24k gold and palladium plated contacts. The conductors of the cable are made of high purity PC-OCC-A copper with a cross section of 5.5mm², ensuring perfect electrical conductivity. The cable can withstand voltages up to 600V and currents up to 30A. This makes the Oyaide Tunami GPXe suitable for transmitting high power signals.
Reference : 12615
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
It is also protected against noise and interference by a triple layer shielding. Its structure rejects not only internal and external noise, but also parasitic noise due to vibrations.
PC-OCC-A copper as conductor
PC-OCC-A copper is a very pure material, allowing any signal to pass through without hindrance or distortion. It is the combination of high technology and Japanese craftsmanship that gives it an extremely pure structure, ensuring optimum performance.
Strong shielding
This Tunami GPXe cable has a triple shielding. The first layer converts electromagnetic waves into thermal energy through an electromagnetic insulator. The second layer is a semi-conductive carbon layer that allows to discharge static electricity without affecting the main conductor. The last layer uses a copper foil that offers two advantages: it protects the conductor from external noise and it allows a grounding.
A highly efficient insulation
The insulation chosen here by Oyaide for its Tunami GPXe cable has the effect of eliminating the negative effects of vibrations thanks to a different degree of internal and external hardness.
OYAIDE TUNAMI GPXe Câble secteur PC-OCC-A IEC C13 Plaqué Or 24k Palladium 1.8m
High quality connectors (P-046e/C-046e)
The connectors (P-046e and C-046e) present on this 1.8m cable have been specially designed for this cable. Their 24k gold and palladium plated contacts make them high quality connectors, ensuring both a very good conductivity and resistance to oxidation.
Product typePower cable
Length 1.8m
Outer diameterØ11mm
Cable conductors materialPC-OCC-A copper
ConnectorsP-046e
C-046e
Connectors contacts plating24k gold
Palladium
Rated voltage/current125V / 15A CE
ColorCable: Black
Connectors: Red
Quantity1* Oyaide Tunami GPXe cable
Length (m)1.8
ShieldingYes
Section (mm²)N/A
ConnectorIEC C15
ConnectorSchuko
Parfait
Branché sur une barrette actinote grande musicalité très bons timbres ça ouvre
Tout cela sans être fatiguant au contraire on en redemande !
Bref a ne pas essayer sinon ...
This review has been posted for OYAIDE TUNAMI GPXe V2 Power Cable Schuko IEC C15 PC-OCC-A Copper Gold 24k Palladium Plated 1.8m
This high quality Oyaide Tunami GPXe power cable is equipped with a Schuko and an IEC C15 connectors, with 24k gold and palladium plated contacts....
